sqhatch Posted May 5, 2005 Share Posted May 5, 2005 I have been looking into this : http://www.quicktimeperformance.com/QTEC/ My first question is will it pass inspection if its in the closed position? I think it'd be a neat upgrade that allows to you run basically a straight exhaust from the downpipe or midpipe after the last cat for some additional ponies. The site stated a wrx made 21 whp and 24 lbs. torque using it. Would it make the ecu run rich/lean? Any negatives can anyone see in reliabiliity or cels if i run it after the last cat? I drive too much everyday to run an aftermarket exhaust so i thought on my fun days (track days or days off) i could crank this open alittle. Any opinions or thoughts are appreciated. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted May 5, 2005 Share Posted May 5, 2005 I may do the same after I get my mufflers welded. I can't see any reason for it to fail emissions. Link to comment Share on other sites More sharing options...
Drift Monkey Posted May 5, 2005 Share Posted May 5, 2005 That QTP DP is way overpriced IMO... Link to comment Share on other sites More sharing options...
sqhatch Posted May 5, 2005 Author Share Posted May 5, 2005 Can you reccomend a cheaper version of equal or better quality? I would prefer the electric ones over the pull cables. Emissions i could understand it passing if its closed, but visual inspection it would pass too? What about a cop looking underneath the car for some reason and seeing it? any fines? i wouldnt be running around w/ it full wide open but i dont want to waste my time w/ it if its gonna fail or fine me. Link to comment Share on other sites More sharing options...
