Zac88 Posted October 28, 2010 Share Posted October 28, 2010 looking into getting a COBB APv2 and going stage 1. 05 LGT with 140,000km on it. All stock besides Cobb SF intake and STi Genome axle backs. Changed the plugs in April. Anything else I should do before? Also I have access to 94 octane fuel, can I run the 93 map without problems? Link to comment Share on other sites More sharing options...
RJS5689 Posted October 28, 2010 Share Posted October 28, 2010 Make sure the car is in good shape and is up on its maintenance. Other than that you're good to go! Stage 1 is an easy, simple flash and doesn't create complications. You'll be fine running 94, it should actually give you a little more protection against detonation, "knock." Link to comment Share on other sites More sharing options...
rice_rocket Posted October 28, 2010 Share Posted October 28, 2010 Nada... also, being higher in altitude it is just safer to run high octane. Good 'ol esso and Canadian gas! I might suggest looking into custom mail in flashes since it might help to tailor for Alberta's climate. Link to comment Share on other sites More sharing options...
Zac88 Posted October 28, 2010 Author Share Posted October 28, 2010 Will I need to upgrade my TMIC? Link to comment Share on other sites More sharing options...
rice_rocket Posted October 28, 2010 Share Posted October 28, 2010 No bother.. but it certainly won't hurt if you want to start upgrading Weather is better in Alberta than most of the states anyways.. it's cooler, and dryer. Too bad high altitude is going to hurt you. I was born and raised in Calgary.. and let's say moving to sea level made everything more powerful.. especially turbo cars! Zoom! Link to comment Share on other sites More sharing options...
