allwheeldrive Posted October 22, 2010 Share Posted October 22, 2010 I know there have been a few 60K maintainance threads but I wanted to get some opinions nonetheless... Found this at a local shop: Lube Oil and Filter : 34.95 Coolant Service : 65.00 Fuel Filter : 55.00 Air Filter : 18.00 Brake Flush : 55.00 Rotate Tires : N/C Spark Plugs : 95.00 (1 Step Colder) Add Synthetic Oil for and additional $50 Synthetic Trans and Diff Service: $119 Total of 491.95 plus tax The service includes checking the following: Drive belts, cam belt, transmission and differential, automatic trans fluid condition if necessary, brakes, clutch, steering and suspension etc. As always, all fluids are topped off automatically. Depending on the conditions you drive your vehicle in, you may need to check some items more frequently than the scheduled interval. is this a good price? Is everything included that should be included? What about changing to colder plugs? Necessary? Thanks in advance Link to comment Share on other sites More sharing options...
m sprank Posted October 22, 2010 Share Posted October 22, 2010 I think AZP probably does far more for less. Done by Subaru (enthusiast) specialists. They are in Jersey. Give them a call/PM. Link to comment Share on other sites More sharing options...
AZP Installs Posted November 8, 2010 Share Posted November 8, 2010 Thanks Mike! Yup we have our prices up on our website under http://AZPInstalls.com in the Maintenance section. On the newer Subarus the fuel filter isn't a serviceable part. We use Amsoil gear oil and have a whole host of motor oils available as well. -mike Link to comment Share on other sites More sharing options...
