LISpecB07 Posted October 20, 2010 Share Posted October 20, 2010 Suspension Gurus, My current setup: Perrin 25MM Rear Sway (set soft) Perrin 22MM Front Sway (set soft) Perrin End Links Tein Comfort Sport Coilovers (set 12 clicks from hard) Conti Extreme Contact 225/40/18 @ 38psi These settings work for my daily driving but since the weather has been getting colder the ride is really harsh. Any recommendations on what to try first would be appreciated. Link to comment Share on other sites More sharing options...
mustangendsley Posted October 20, 2010 Share Posted October 20, 2010 I would say lower your air presure to 32psi recomended on the door tag. I have 25 mm f/r bars and msi endlinks, mine is always harsh in the am due to the colder temps. once everything gets working it will be a better ride in about 5 miles of driving. Link to comment Share on other sites More sharing options...
rs6er Posted October 21, 2010 Share Posted October 21, 2010 Disagree with the above poster. I normally run 38-40 lbs in my 235/40/18 tires. When the temp drops, so does the air pressure— with a resultinly hard ride. When I get the air pressure back into my range, the ride regains its smoothness. Link to comment Share on other sites More sharing options...
mwiener2 Posted October 21, 2010 Share Posted October 21, 2010 get cold weather tires My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
