Mario500 Posted October 19, 2010 Share Posted October 19, 2010 1997 Subaru Legacy GT 2.5 While filling my tires with air, using a my lighter socket to plug in the pump, the socket stopped working. I've plugged in my GPS and phone charger to confirm and it's definitely dead. I've changed EVERY fuse under the hood and dash (just in case they were labeled incorrectly) and found no blown fuses. The inside of the socket looks fine and has no burn marks. I really don't want to remove the dash to take out the lighter. Does anyone have any ideas on what can be done? Is there an inline fuse I can't see or reach? Can the socket be removed for the front? I really need this socket to work. Any help will be appreciated. Thanks Link to comment Share on other sites More sharing options...
subie3429 Posted October 19, 2010 Share Posted October 19, 2010 This happened to me on my old car, the wire came off the back of the lighter. Link to comment Share on other sites More sharing options...
Mario500 Posted October 21, 2010 Author Share Posted October 21, 2010 Finally I had some free time to try to get the lighter out. The trick was getting the cupholder out first, then it was easy. I'm very pleased I didn't have to remove the entire dash. After removing the lighter I tested the wires and found the socket was getting juice. On the back of the socket there is one tiny wire that connects two metal plates. It would appear the wire has been burned it half. Maybe the tire pump was too much for it. Once I pick up a new socket it should work fine. Thanks for your input. Link to comment Share on other sites More sharing options...
subie3429 Posted October 21, 2010 Share Posted October 21, 2010 Glad you got it! Link to comment Share on other sites More sharing options...
LongHiway Posted October 21, 2010 Share Posted October 21, 2010 I did the same thing once. The power adapter created a short in the ligher assembly and burnt a wire before blowing a fuse. Link to comment Share on other sites More sharing options...
Mario500 Posted October 23, 2010 Author Share Posted October 23, 2010 I think I'll change the fuse from a 20 to a 15 and see if that helps. It's much easier and cheaper to change a fuse. Link to comment Share on other sites More sharing options...
