Mbohn007 Posted October 15, 2010 Share Posted October 15, 2010 I recently bought my wife a 2008 Subaru Legacy, and im looking to put a new set of wheels and tires on it. Im looking at a set of TSW Zolders. 5x100 - 18x8 - 35 offset. Ive been told mixed things as to weather or not they will fit or not. The car has not been lowered. So the big question, will they fit? Link to comment Share on other sites More sharing options...
W1CKED Posted October 15, 2010 Share Posted October 15, 2010 Here we go, here are your choices for rim widths (regardless of it being 17", 18", 19" or 20" rims): {offset in BOLD are the closest possible offset to OEM's scrub radius, you'll notice that once you go past 8" wide rims, you will run out of room on the inboard side to put/stuff any more of the wheel/tire to maintain the OEM scrub radius.. 8" and up will increase positive scrub radius} 6.5" (+34mm to +60mm offset, +55) *for 2.5i only 7.0" (+37mm to +57mm offset, +55) 7.5" (+40mm to +54mm offset, +55) 8.0" (+43mm to +51mm offset, +53) 8.5" (+45mm to +48mm offset, +45) *will need to roll the fenders if tires are wider than 255 9.0" (+43mm to +45mm offset, +43) *will need to roll the fenders if tires are wider than 255 9.5" (+38mm to +40mm offset, +38) *will need to roll the fenders if tires are wider than 255 and it also depends on what kind and size of tire you want to run as well (and that can get messy). But to be on the safe side, here is the tire widths you can put on each rim: 195mm = 6.5", 7" and 7.5" 205mm = 6.5", 7" and 7.5" 215mm = 6.5", 7", 7.5" and 8" 225mm = 7", 7.5", and 8" 235mm = 8", 8.5", and 9" 245mm = 8", 8.5", and 9" 255mm = 8.5", 9", and 9.5" 265mm = 8.5", 9", and 9.5" 275mm = 9" and 9.5" 285mm = 9" and 9.5" From THIS THREAD. Link to comment Share on other sites More sharing options...
Mbohn007 Posted October 20, 2010 Author Share Posted October 20, 2010 I appreciate the help. I settled on a set of 19x7.5 Kyowa KR_206's (the REV Model II knock-offs). Thanks again! Link to comment Share on other sites More sharing options...
