vadimr Posted October 14, 2010 Share Posted October 14, 2010 Folks, I've read a few threads here about how much of a PITA it is to get to the MY05-06 PCV out of LGT. However the part number for MY07-09 it totally different and is twice as cheap, does anyone know it's location and how easy is it to get to it? Thanks, Vadim Link to comment Share on other sites More sharing options...
vadimr Posted October 15, 2010 Author Share Posted October 15, 2010 anyone? Link to comment Share on other sites More sharing options...
shtbxr22 Posted October 16, 2010 Share Posted October 16, 2010 yes. the newer PCV is a two piece, but i highly recommend(must) you get both the plastic "tee" that the PCV threads into, and the PCV itself. the stock ones are locked in with some glue, so you will break it trying to get the pcv out. also, if you don't have WD-40 or strong arms, you should get an "oettiker" clamp tool http://www.amazon.com/s?ie=UTF8&rh=n%3A16310091%2Cp_4%3AOetiker&page=1 and the location of the PCV is under the intercooler. take it off, and you should see the plastic tee, and the PCV itself. enjoy! Link to comment Share on other sites More sharing options...
oside13 Posted October 16, 2010 Share Posted October 16, 2010 yes. the newer PCV is a two piece, but i highly recommend(must) you get both the plastic "tee" that the PCV threads into, and the PCV itself. the stock ones are locked in with some glue, so you will break it trying to get the pcv out. also, if you don't have WD-40 or strong arms, you should get an "oettiker" clamp tool http://www.amazon.com/s?ie=UTF8&rh=n%3A16310091%2Cp_4%3AOetiker&page=1 and the location of the PCV is under the intercooler. take it off, and you should see the plastic tee, and the PCV itself. enjoy! I agree I changed mine and the whole time I was worried about cracking the plastic piece and it took alot of force to get it apart. Buy both pieces! Link to comment Share on other sites More sharing options...
