Fish Posted October 6, 2010 Share Posted October 6, 2010 Hi guys, Any advice would be much appreciated. My front left axle appears to be slowly leaking grease and there's a slight humming that just started in the area. What is the easiest way to fix this? Will replacing the axle solve the problem? http://i146.photobucket.com/albums/r243/kf6pzl/IMGP0434.jpg http://i146.photobucket.com/albums/r243/kf6pzl/IMGP0442.jpg Thanks again! Chase Link to comment Share on other sites More sharing options...
Fish Posted October 6, 2010 Author Share Posted October 6, 2010 I should mention this is a 96 Legacy Wagon, 70k miles. Link to comment Share on other sites More sharing options...
rshaw123 Posted October 6, 2010 Share Posted October 6, 2010 I have two new axles (10000 miles approximately) from my car for sale if you need new ones. Link to comment Share on other sites More sharing options...
Chuckadian Posted October 6, 2010 Share Posted October 6, 2010 Mine leak from there too, it's pretty common for those seals to go out. But that said, I leak transmission fluid, I'm not sure why you would lose so much grease from that spot... Link to comment Share on other sites More sharing options...
subikid90 Posted October 6, 2010 Share Posted October 6, 2010 I wouldnt be worried about grease right there. Check to make sure your boots are not torn, if they arent then you should be fine. If you have a bad clunking noise while turning slow then replace them. Otherwise don't waste money lol Not trying to kill your sale rshaw123 lol -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Fish Posted October 6, 2010 Author Share Posted October 6, 2010 Boots are in fine shape. Link to comment Share on other sites More sharing options...
rshaw123 Posted October 6, 2010 Share Posted October 6, 2010 I wouldnt be worried about grease right there. Check to make sure your boots are not torn, if they arent then you should be fine. If you have a bad clunking noise while turning slow then replace them. Otherwise don't waste money lol Not trying to kill your sale rshaw123 lol its fine i was just throwing that out there if he needed them. Link to comment Share on other sites More sharing options...
