SXCMNX Posted October 6, 2010 Share Posted October 6, 2010 Car was running fine, went around a corner, big back fire then lost power. will turn over but wont fire, have checkd fuel lines, plenty of pressure. Checkt that there is spark. And checkd ignition fusez. cannot see what else the problem could be? Link to comment Share on other sites More sharing options...
subikid90 Posted October 6, 2010 Share Posted October 6, 2010 Check for compression. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
SXCMNX Posted October 7, 2010 Author Share Posted October 7, 2010 Ummm compression where, there is a few places i could check for it but where in this instance? Link to comment Share on other sites More sharing options...
brittcrowell Posted October 9, 2010 Share Posted October 9, 2010 Compression is always checked at the spark plugs. My guess is its possible that you broke a timing belt. If the valves aren't moving, you wont have any real compression because either an exhaust or intake valve is open in some partial position since the are not moving. Link to comment Share on other sites More sharing options...
