cd_legacy Posted October 3, 2010 Share Posted October 3, 2010 I need to replace the factory exhaust and am considering an aftermarket system, my question is can I get away with this without an ECU upgrade because of lack $$$ for both..I have a 05 LGT and an AVO drop-in filter, AVO MAF hose and a resonator mod the rest is stock..Thank you for your help Link to comment Share on other sites More sharing options...
rtbrjason Posted October 3, 2010 Share Posted October 3, 2010 If you should be fine if you're talking about a catback. I wouldn't run a downpipe without a tune though. Link to comment Share on other sites More sharing options...
Scooby Fan Posted October 3, 2010 Share Posted October 3, 2010 I am running an AVO panel filter and full AVO CBE......runs and sounds great...no tune needed. http://i23.photobucket.com/albums/b375/RM-RS/AVOfull.jpg Link to comment Share on other sites More sharing options...
dugan.wsu Posted October 3, 2010 Share Posted October 3, 2010 I went with the Magnaflow CBE, easy install and no ECU. No issues, runs great! Link to comment Share on other sites More sharing options...
peteyjr Posted October 3, 2010 Share Posted October 3, 2010 You could run a bit lean with a higher flow filter. Link to comment Share on other sites More sharing options...
cd_legacy Posted October 3, 2010 Author Share Posted October 3, 2010 Thanks for the replies and the pic Scoob..The AVO system looks nice and ive heard good things about the Magnaflow CBE....decisions, decisions... Link to comment Share on other sites More sharing options...
rtbrjason Posted October 4, 2010 Share Posted October 4, 2010 You could run a bit lean with a higher flow filter. You definitely will, but the stock tune is so rich that it should be well within the margins of safety. Link to comment Share on other sites More sharing options...
