Bannonjr Posted September 20, 2010 Share Posted September 20, 2010 Hey guys, I'm trying to replace a busted brake line on the passenger rear. The lines go under the back seat, through the floor, into a lil box and disappears above the gas tank. I can't tell which is which, anyone have a diagram or an easier solution? I've searched for a diagram everywhere and can't seem to find one...even in the manual. Thanks in advance guys! Link to comment Share on other sites More sharing options...
Bannonjr Posted September 20, 2010 Author Share Posted September 20, 2010 Sorry, it's a 98 Legacy L 2.2 AWD Link to comment Share on other sites More sharing options...
worknlikeadog Posted September 20, 2010 Share Posted September 20, 2010 are you replacing the whole line, or just a segment. I had to do this before I ended up replacing the busted part. I started under the seat and ended the new segments just after where the little box used to be. I took it out Link to comment Share on other sites More sharing options...
Bannonjr Posted September 21, 2010 Author Share Posted September 21, 2010 Both lines, are broken or both sides of that lil box...so I guess I need to know which ones go where. I really don't wanna drop the fuel tank for this Link to comment Share on other sites More sharing options...
worknlikeadog Posted September 21, 2010 Share Posted September 21, 2010 just do what i did, Patch start under the seat and then go past the box where the line is the nicest. The box is only what it looks like just a spot for it to rust really bad. The lines just go strait through so the one coming in on the left can just splice to the one going out on the left side and visa~versa Link to comment Share on other sites More sharing options...
Bannonjr Posted September 21, 2010 Author Share Posted September 21, 2010 Ok...took a closer look underneath...it's completely rotted on both sides of that lil box.. Now, I guess I'll just run a new line, from inside the car (under back seat) to each caliper hose, could you tell me which one goes to which? I'll guess the line under the back seat which is closet to the outside of the car goes to the right, and vice-versa? Link to comment Share on other sites More sharing options...
Bannonjr Posted September 21, 2010 Author Share Posted September 21, 2010 I also took a look on the driver side under the seat and there is 3 lines...are they brake or fuel and if they're brake..where do they go? Link to comment Share on other sites More sharing options...
worknlikeadog Posted September 22, 2010 Share Posted September 22, 2010 drivers side is feul the bes way to see where the line goes when it goes under the car is to trace it, wiggle or cut one pull it through just fix one at a time Link to comment Share on other sites More sharing options...
Bannonjr Posted September 25, 2010 Author Share Posted September 25, 2010 For anyone who searches for this: On the drivers side under the seat, the line closest to the door (outside line) is for the drivers side, and vice-versa. I ran a new line direct from the backseat, one to each caliper, skipping the lil rusty box. The line to the drivers side I ran in the car under the back seat and poked a hole in the spare slot in the fuel line grommet. I replaced all the brakes with Mountain Rotors and PBR pads...bled the brakes and it is now amazing...the rotor/pad upgrade is awesome. Link to comment Share on other sites More sharing options...
