Napping Posted September 20, 2010 Share Posted September 20, 2010 Was doing HG replacemnt/engine swap on 98 Legacy Outback and after pretty much done, found this part left over... http://i52.tinypic.com/2yphyc1.jpg And I can't figure out where is it from. Link to comment Share on other sites More sharing options...
98quiksilvergt Posted September 20, 2010 Share Posted September 20, 2010 It kinda looks like part of a motor mount!!! Lol! Link to comment Share on other sites More sharing options...
amp27 Posted September 20, 2010 Share Posted September 20, 2010 accessory mount part? wheel bearing? rotor? rear diff? volume knob? at least i tried my hardest to help Link to comment Share on other sites More sharing options...
Napping Posted September 21, 2010 Author Share Posted September 21, 2010 I only did engine and engine swap work. didn't touch rest of the car. it does look like an accessory mount would look like, except i couldn't find where it goes lol. and nothing looks similar under the hood of my 99 legacy. Link to comment Share on other sites More sharing options...
98quiksilvergt Posted September 21, 2010 Share Posted September 21, 2010 Hmm.... Link to comment Share on other sites More sharing options...
amp27 Posted September 21, 2010 Share Posted September 21, 2010 drive it. it dont look like an internal part so what could possible go wrong? motor falls out the car? o well Link to comment Share on other sites More sharing options...
subikid90 Posted September 21, 2010 Share Posted September 21, 2010 I swear I have seen that somewhere. I will take a look tonight when I get home and see if I can find it -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Napping Posted September 21, 2010 Author Share Posted September 21, 2010 I've been told it's fuel rails bracket cover. if that's the case, then it's a non-issue, since then it's from a different project, where I did took intake manifold completely apart. Link to comment Share on other sites More sharing options...
ehsnils Posted September 21, 2010 Share Posted September 21, 2010 Looks like one of the lifting points for the engine. Link to comment Share on other sites More sharing options...
skibob6 Posted September 21, 2010 Share Posted September 21, 2010 Looks like one of the lifting points for the engine. ^ I agree looks like a factory lift point. Link to comment Share on other sites More sharing options...
Napping Posted October 21, 2010 Author Share Posted October 21, 2010 Found it! the above described work was a bust due to forseter block having a rod knock. So i went and bought low-milage jdm engine for new swap and there it was: the very same braket mounted to passenger side of the engine, holding jdm exhaust in place. Since I'm using eom exhaust, I have no need for it. Mystery solved. Link to comment Share on other sites More sharing options...
