babybaluga32 Posted September 16, 2010 Share Posted September 16, 2010 So i welded an up and down pipe using flexible exaust tubing both are under 2". Yes thats way retarded for the downpipe but for now im content. Im wondering if it will be bad if there are any TINY! holes? I doesnt like to get hot so the welds start to burn through.. Any Suggestions? Thanks Link to comment Share on other sites More sharing options...
mdzowner Posted September 16, 2010 Share Posted September 16, 2010 i suggest you read your post before you post it so you might actualy get an answer to what ever question it is you are asking. Link to comment Share on other sites More sharing options...
amp27 Posted September 16, 2010 Share Posted September 16, 2010 yea, thats worse then me sometimes hhahaha Link to comment Share on other sites More sharing options...
babybaluga32 Posted September 16, 2010 Author Share Posted September 16, 2010 Sorry.. Im wanting to know if a weld that is not completely sealed and has a very very minimal amount of air escaping will affect anything major? Link to comment Share on other sites More sharing options...
chutrain Posted September 16, 2010 Share Posted September 16, 2010 I recommend you finding someone who knows how to weld. If you have tiny holes, it probably means that there are areas that are not welded probably and will most likely fail down the road. I say fork the money over for an aftermarket piece and not worry about it, or find a shop that can go over it for you. Link to comment Share on other sites More sharing options...
