Ridgeracer Posted September 8, 2010 Share Posted September 8, 2010 If you have another intake outside of stock, what is the correct procedure for adjusting this table?? "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
Spec B Posted September 8, 2010 Share Posted September 8, 2010 I do not know of any. I adjusted mine to deal with some serious high end AFR leaning in the heat...now after adjusting it, I just run uber rich on the high end. Interstingly, I think the 07+ models have this table zero'd out. Link to comment Share on other sites More sharing options...
Ridgeracer Posted September 9, 2010 Author Share Posted September 9, 2010 A little side note as far as AFRs go in OL. In all the logs I have done, I have never noticed a difference in power from running 10.5 vs 11 AFR. Have you? Anything over 11.2 I knock.. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
Spec B Posted September 9, 2010 Share Posted September 9, 2010 Airboys sheet shows no difference in power (in the high end) when I stray from my 11.1 target to say 10.6, but I do get the occasional backfire. Before I played with the comp table, I had leaned out to 12.0 at 5500 rpm in one run...it knocked one time. My car seems to resist knock up until 11.6-11.7. By adjusting the iat comp table, I managed to get it to run rich instead of lean..its a tough table to fine tune tho, the changes are pretty dramatic. Link to comment Share on other sites More sharing options...
Ridgeracer Posted September 9, 2010 Author Share Posted September 9, 2010 My car seems more happy with boost vs higher timing or lean AFRs. Better for the rod ends anyways. What kind of adjustments did you make? "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
Ridgeracer Posted September 12, 2010 Author Share Posted September 12, 2010 Well for the past few days I have been playing around with this table and doing some 3rd gear pulls to check for changes in AFR vs temp. I started out with the table NSFW posted on RR. Looks promising so far. Will hopefully have a table to post by next week for some more feedback.. BTW...This is all done on an AVO hot air intake.. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
LittleBlueGT Posted September 12, 2010 Share Posted September 12, 2010 FWIW, as long as you are plaing with g/s numbers higher then 80 g/s you can use this table to run different AFRs in different temps. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
bugblatterbeast Posted September 13, 2010 Share Posted September 13, 2010 there's also a trim to the primary open loop table based on IAT timing compensation which will work for changing AFRs as a function of temp. I prefer to use that one as it doesn't skew the load calculations which will then skew timing. Link to comment Share on other sites More sharing options...
Ridgeracer Posted September 13, 2010 Author Share Posted September 13, 2010 That table might be a better option. Thx "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
LittleBlueGT Posted September 13, 2010 Share Posted September 13, 2010 there's also a trim to the primary open loop table based on IAT timing compensation which will work for changing AFRs as a function of temp. I prefer to use that one as it doesn't skew the load calculations which will then skew timing. Didn't know that existed, thanks. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
Ridgeracer Posted September 15, 2010 Author Share Posted September 15, 2010 Well here are the changes to the above referenced tables. The POL comp table has a 0.02 offset for timing comps of -2 degs or more. I run 11.0 AFR for WOT so effective AFR should be 10.8 for extra room. I included three logs with IAT also included. Two were taken with IAT above 95. The next with IAT below 75. Prior to these changes, my car would run 0.5 leaner in the warm temps and closer to POL target in cool weather. Naturally the MAF was scaled in cooler temps. My car pulled some timing just due to the heat in the warm weather pulls but AFRs were no longer going over 11 AFR. I already addressed the pulled timing with some changes to the base timing table and IAT timing comp table. I suspect that the FMIC core is too small for my turbo. I think I'll get the AFRs closer now and keep logging.romraiderlog_20100914_041551.csvromraiderlog_20100913_154159.csvromraiderlog_20100913_154029.csv "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
