Xterior Posted September 6, 2010 Share Posted September 6, 2010 So I found a good deal on a set of 09 wagon leather seats. Will there be any problems installing the front seats since they will be both powered? I wanna know of the rest of the plugs are the same other than the power drive plug, that one I can just tap a positive power source from somewhere and then just ground it. Also are the rear seats going to fit? The only comparison I have is just pictures, so was wondering if any of you guys out here have a solid answer for me. If anything I'll just swap the bottom rear seat and the top rear ones I just buy the leather cover from the dealer or something. Link to comment Share on other sites More sharing options...
zmarko Posted September 6, 2010 Share Posted September 6, 2010 They are not plug and play. Search for JDMchizad's thread of swapping 07 seats into his 05 and the troubles he had. Physically they should fit perfectly (fronts). The rears on the 09's are the folding down type, so your '05 isn't rigged for that (I believe someone has gotten it to work, just don't know what's needed). Use the search function and you'll find what you need. Link to comment Share on other sites More sharing options...
Xterior Posted September 6, 2010 Author Share Posted September 6, 2010 Thanks, I tried searching but no one has a solid has yet posted about wagon seats into sedans. Link to comment Share on other sites More sharing options...
Xterior Posted September 30, 2010 Author Share Posted September 30, 2010 anyone else? Link to comment Share on other sites More sharing options...
