NorthernVTGT Posted August 24, 2010 Share Posted August 24, 2010 2005 LGT 5MT was making serious TOB noise. Parked it for several months and then ordered the following from Fred Beans: '07+ SMFW'07+ Clutch disk'07+ Pressure Plate'07+ TOB8 new hex-head FW bolts Had the whole shebang installed by a good local shop with Subaru/Honda specialty. I am now in reverse hell. After a good first week, now the trans is making a cricket-like sound IN gear. Not the TOB squeal, but crickets. Not with clutch pedal depressed, but once full engaged and in gear, I get a faint crickets sound. Push clutch pedal = silent. Idle in neutral = silent. Drive in gear (especially third = crickets). Before today's long drive (180 miles highway) gear oil was full. Can't get at dipstick as I am outside of Boston without tools to pull the engine cover. Any ideas? Search didn't help me. Vague ideas of adjustment issues and loose mounts on other boards. Link to comment Share on other sites More sharing options...
lucas569 Posted August 24, 2010 Share Posted August 24, 2010 i thought i remember something about putting a spring on the tob like the sti has http://legacygt.com/forums/showthread.php/my-tob-squeal-solution-alt-clutch-fork-return-spring-91377.html?t=91377&highlight=return+spring+fork Link to comment Share on other sites More sharing options...
NorthernVTGT Posted August 25, 2010 Author Share Posted August 25, 2010 Thanks for the idea. At least something to research that doesn't include opening up the housing. I vaguely recall another post talking about clutch pedal adjustment/loading on the LGT. Do any of the more experienced (than me) on here have a thought on that? Appreciate the help. I am hearing some wheel bearing noise now and one of the rear strut mounts in clunking. My 10/2004 LGT is showing its age. Link to comment Share on other sites More sharing options...
spartan Posted August 25, 2010 Share Posted August 25, 2010 try putting pressure on your shift lever when you hear the noise. I am getting a simular noise with my stock DMFW and it is especially pronounced in third, if I put my hand on the shifter the noise stops. Just a thought... Link to comment Share on other sites More sharing options...
