wrxkilla05 Posted August 23, 2010 Share Posted August 23, 2010 so it just started happening the other day but i noticed that when my car is not moving and i try to turn the wheel while the car is on of course, the wheel hesitates and seems to skip? and my battery light was flickering on and off...i checked my belts and my fluids and everything is good..it doesnt affect my daily driving at all i just thought it was really weird and didnt know if any1 else has had the same problem Link to comment Share on other sites More sharing options...
king_j Posted August 23, 2010 Share Posted August 23, 2010 how does it sound? does it make a "normal" power steering noise? Link to comment Share on other sites More sharing options...
TRSCobra Posted August 24, 2010 Share Posted August 24, 2010 Definately seems like a belt issue. If the belts are tight, make sure they're not all cracked or glazed up. Link to comment Share on other sites More sharing options...
wrxkilla05 Posted August 24, 2010 Author Share Posted August 24, 2010 the last time it happened i did hear a screech out of the belts but not too bad....its not rubbing or frayed or cracked or anything of the sort Link to comment Share on other sites More sharing options...
wrxkilla05 Posted August 24, 2010 Author Share Posted August 24, 2010 this may go along with my other problem but when i start up my car and before its warmed up everything sounds fine but when i push in the clutch i hear a faint screeching noise and it doesnt stop until i either let off the clutch or touch the gas.... Link to comment Share on other sites More sharing options...
