Bassnectar Posted August 19, 2010 Share Posted August 19, 2010 do I go in the x patter or front to back when rotating tires on a 1998 legacygt im in the process of replacing the front struts, so might as well rotate the wheels while im at it since i will need to take it in for an alignment haynes says front right goes to rear right but ehow says front right goes to rear left what do you actual owners do, thanks Link to comment Share on other sites More sharing options...
G.T.Subie Posted August 19, 2010 Share Posted August 19, 2010 Do you have directional tread patterns on your tires?? Denial is your best friend Link to comment Share on other sites More sharing options...
Mega Users LieutenantDan Posted August 19, 2010 Mega Users Share Posted August 19, 2010 .......because if you do, you would just go front to back and vice versa .......if you don't, do the x Link to comment Share on other sites More sharing options...
leftride Posted August 19, 2010 Share Posted August 19, 2010 what do you actual owners do um, i read the manual... front to back, same side, 06 xt. *vb gallery* Link to comment Share on other sites More sharing options...
Sydtron Posted August 19, 2010 Share Posted August 19, 2010 If you have asymmetrical or non-directional tires, do X. If you don't, do front-back. You'll squeeze a few more miles out of them with an X but it shouldn't really be night and day difference between the two patterns. Link to comment Share on other sites More sharing options...
