Jeffzguy Posted August 9, 2010 Share Posted August 9, 2010 I have a 91 legacy l sedan automatic, if I were to get a 91 legacy l wagon with a 5 speed could I just bolt everything in? I would need the flywheel, clutch assembly, trans and the ecu with harness? Maybe even the gauge cluster is that all? Basically just replace flexplate with flywheel and bolt in the clutch and trans then swap the wiring and ecu and fire it up? Oh and is the wiring I would need to swap seperate from the body harness, like does it disconnect at the firewall like my nissan? Link to comment Share on other sites More sharing options...
wish Posted August 9, 2010 Share Posted August 9, 2010 better off just buying that wagon and selling your car. too much of a hassle. wagons also have cheaper insurance and are just way more useful cause you can haul so much more stuff. Link to comment Share on other sites More sharing options...
Jeffzguy Posted August 9, 2010 Author Share Posted August 9, 2010 But the wagon has a blown head gasket and bald tires... Link to comment Share on other sites More sharing options...
sqc151 Posted August 9, 2010 Share Posted August 9, 2010 iirc u dont need to change the harness. Link to comment Share on other sites More sharing options...
Jeffzguy Posted August 9, 2010 Author Share Posted August 9, 2010 So its just ECU, trans and clutch stuff, and a bunch of work? How about gauges, will it matter that the gauges have the auto trans selector stuff on it? Link to comment Share on other sites More sharing options...
sqc151 Posted August 12, 2010 Share Posted August 12, 2010 also u might be able to get away with an auto ecu too. (i have to find the thread i read awile back)(but for the 50 bucks might as well get a manual ecu) gauges should be fine. but if u can find a manual cluster get it. Link to comment Share on other sites More sharing options...
Jeffzguy Posted August 12, 2010 Author Share Posted August 12, 2010 Oh and pedals, and I would have to bolt up a clutch master cyl Link to comment Share on other sites More sharing options...
