Lexxster Posted August 7, 2010 Share Posted August 7, 2010 Need one badly!!! Blew mine on memorial and have had no luck locating another. If someone could help me find one or a replacement option that would be great. Link to comment Share on other sites More sharing options...
tailgatewagon Posted August 8, 2010 Share Posted August 8, 2010 if you cant find one do a swap from a 411 or 444 diff you can read about it on ultimatesubaru.org. bassicaly you take your diff apart and use the carier out of the 411 or 444 diff in your diff youi keep your ring and pinon. ive done it on several cars and never had problems you may have to mix it up with the axles a bit to get everything to work but its going to be kinda custom anyway. sorry about the spelling im in a hurry... Link to comment Share on other sites More sharing options...
sqc151 Posted August 8, 2010 Share Posted August 8, 2010 any junkyards by u? u can get an open 3.90 for now till u find a vlsd. Link to comment Share on other sites More sharing options...
Lexxster Posted August 8, 2010 Author Share Posted August 8, 2010 True on the open, which is what i will probably have to do. As far as changing the gear ration to 411, i would have to change the front transfer and the tranny shaft, checked into it and that would be a lot of money and work. Wish someone out there had a 91 3.90 viscous. Link to comment Share on other sites More sharing options...
tailgatewagon Posted August 9, 2010 Share Posted August 9, 2010 i was not suguesting that you turn your car into a 4.11 or 4.44 if your lsd is shot here is what you do use the 4.44 or 4.11 lsd and put it in your 3.9 housing then you have a 3.9lsd... here are some directions. they involve the 3.7lsd(not vlsd) and to 3.9lsd but it works for lsd or vlsd swaps in general... good luck... pm me and ill drop you my ph if you want me to try and explain it over the phone.... http://www.ultimatesubaru.org/forum/showthread.php?t=49924 Link to comment Share on other sites More sharing options...
Lexxster Posted August 9, 2010 Author Share Posted August 9, 2010 cool, sounds like an option, need to pull my diff and see if the housing is damaged. Link to comment Share on other sites More sharing options...
