slipshod77 Posted August 4, 2010 Share Posted August 4, 2010 Two weeks ago my wife's bone-stock 2005 LGT wagon (62k miles) threw a code right at a warm startup. Using the built in code reader (thank you, forum) it turned out to be P0302. I cleared it and hoped it was a fluke. Today it came back, and again it happened right after a warm startup. The car seems to run fine, although the idle might be *slightly* more rough than usual. After some searching of the forum, I swapped the injector with the one from cyl#4 and the coil pack with the one from cyl#1. Comparing the spark plugs from cylinders 1 and 2 I didn't see much of a difference. Anyone care to guess where the code pops up again? At #1 (coil pack), at #4 (injector) or #2 (none of the above)? Whoever guesses correctly gets a warm fuzzy feeling and bragging rights. Also, I noticed that the coil pack for cylinder #3 was loose, I could wiggle it with my fingers (the dealer performed the 60k service about a month ago). I tightened it down while I was in there. How that would cause a #2 misfire is beyond me, but I suppose anything's possible. I'll post with updates as they happen. Enjoy! Link to comment Share on other sites More sharing options...
imcabby Posted August 6, 2010 Share Posted August 6, 2010 we had the same thing.. it was the injector... Link to comment Share on other sites More sharing options...
