bluecanary Posted July 30, 2010 Share Posted July 30, 2010 I need to remove the trunk cover to get to the bulbs above my rear licence plate. What is the best way to remove this? I scared of damaging the fixings so that it cannot be properly replaced. Link to comment Share on other sites More sharing options...
CCSubaru Posted July 30, 2010 Share Posted July 30, 2010 Are you talking about interior trunk trim or the exterior of the trunk? Link to comment Share on other sites More sharing options...
SUBACHEVROMAN Posted July 30, 2010 Share Posted July 30, 2010 mine was easy doing...got lights from yourledshop...just remove outter rubber bushings and plastic clips..the trim around emergency latch needs to come off too...just reach behind carpet with it hanging and twist off sockets to install...i wouldnt recommend removing those carpet clips very often because theyll wear out...ive heard of people tearing their outside panel of trunk apart doing this mod...thats not needed..did my leds from the inside of trunk..good luck Link to comment Share on other sites More sharing options...
boymk123 Posted July 31, 2010 Share Posted July 31, 2010 ok, first, stop by Home depot and look for something like this: http://www.beisansystems.com/procedures/rear_shocks_procedure_files/image015.jpg then pop up your trunk, remover all the plastic rivets on it (the one that connect the inner carpet trim with the trunk), took the inner trim out, then you can see the 2 bastards, twist them (you right hand rule thumb) to remove... ... and replace them with the new bastards:) have fun, edit: dont try to remove those rivets without the tool I show you, or you will either tear your finger nails, your carpet trim, or the rivets apart... Once ya done, putting eveything back together takes about 1 mins ..lol Link to comment Share on other sites More sharing options...
burnout8488 Posted July 31, 2010 Share Posted July 31, 2010 Much less frustrating if you do it from the outside. Remove the license plate, and there are two 10mm bolts behind it holding the plastic panel onto the back of the trunk. Pop this panel off and the panel holding the two bulbs will then pry down. This way, you don't have to deal with carpet pop-its, or the inside of the trunk at all. Link to comment Share on other sites More sharing options...
youknowit Posted July 31, 2010 Share Posted July 31, 2010 Much less frustrating if you do it from the outside. Remove the license plate, and there are two 10mm bolts behind it holding the plastic panel onto the back of the trunk. Pop this panel off and the panel holding the two bulbs will then pry down. This way, you don't have to deal with carpet pop-its, or the inside of the trunk at all. Link to comment Share on other sites More sharing options...
bluecanary Posted August 1, 2010 Author Share Posted August 1, 2010 Thanks everyone, I think I'll go in from the outside. Link to comment Share on other sites More sharing options...
