MooseMan Posted April 24, 2005 Share Posted April 24, 2005 My fiance has a '97 Legacy L Auto with about 170,000 miles on it. The thing runs great - but the transmission does some really weird shifting in first and second gear. The best I can tell is that it doesn't actually make it back to first gear and is starting in second. Once in second - it realizes that it needs more power and slams it back to first. I can shift up by hand on the auto shifter and it works fine. Anybody else have this problem? Suggestions? Thanks! Link to comment Share on other sites More sharing options...
boris1 Posted May 21, 2005 Share Posted May 21, 2005 My fiance has a '97 Legacy L Auto with about 170,000 miles on it. The thing runs great - but the transmission does some really weird shifting in first and second gear. The best I can tell is that it doesn't actually make it back to first gear and is starting in second. Once in second - it realizes that it needs more power and slams it back to first. I can shift up by hand on the auto shifter and it works fine. Anybody else have this problem? Suggestions? Thanks! Looks like no one knowledgeable has real advice. I may be completly off but maybe your computer has come to learn to shift that way according to you driving style. I can suggest as a last resort to reset your computer by disconnecting the battery for a minute. Once it is reset, it may "re-learn" to your driving style and shift differently. Link to comment Share on other sites More sharing options...
unobtainium Posted May 21, 2005 Share Posted May 21, 2005 If I recall correctly, it is meant to do that when the car is cold. You are supposed to be able to over-ride its preference to start in second. You might check on the "New Generation" part of the Ultimate Subaru message board, http://www.ultimatesubaru.net. Link to comment Share on other sites More sharing options...
