ironchefireland Posted July 19, 2010 Share Posted July 19, 2010 Here is a link to page 3 of the write up/install guide. Alot of them mention dremelling the metal shroud to get it to fit, though in the write up he says he flips the shroud 180 degrees and it fit OK. When I did mine, the 180 flip looked more trouble than it was worth. The plate looked spot welded in a couple points, so some dremel goodness was needed. I might do a little more since the up gears (1,3,5) have more nvh than the lower (2,4) Link to comment Share on other sites More sharing options...
peteyjr Posted July 20, 2010 Share Posted July 20, 2010 Bushings really help when the stockers wear and have play. This is something the older Subies were famous for. The bushings button down the feel . Not a necessity but worthwhile depending on the milage and wear on the stock bushes. I have both front and rear and NVH is not an issue. Link to comment Share on other sites More sharing options...
Verwilderd Posted July 20, 2010 Share Posted July 20, 2010 Bushings really help when the stockers wear and have play. This is something the older Subies were famous for. The bushings button down the feel . Not a necessity but worthwhile depending on the milage and wear on the stock bushes. I have both front and rear and NVH is not an issue. I'd say they still help a bunch even on newer cars. I have approx 17K miles and changed these and it made a HUGE difference. Link to comment Share on other sites More sharing options...
SP3C7R3 Posted July 20, 2010 Share Posted July 20, 2010 I would recommend this: http://moderacing.com/shop/product_info.php?manufacturers_id=10&products_id=178&osCsid=k5e5ripdrr03teqaufjq0nh1o4 Its basically the same as the Cobb. Minor modification was needed, but double adjustable is the way to go. STI STS is a waste. Link to comment Share on other sites More sharing options...
heferly Posted July 28, 2010 Share Posted July 28, 2010 ... Can tell the stock knob is lower, but will probably get a Delrin STi knob to reduce the height a little bit more... so the stock knob fits the KB sts? don't want to buy a new knob if i don't need it right now sometimes you eat the bar, and sometimes...well, he eats you Link to comment Share on other sites More sharing options...
eldiablo Posted July 28, 2010 Share Posted July 28, 2010 Yes. Stock knob fits on KB sts. My VB Garage... Pumping the air back into despair Link to comment Share on other sites More sharing options...
toreadorranger Posted July 28, 2010 Share Posted July 28, 2010 I'd say they still help a bunch even on newer cars. I have approx 17K miles and changed these and it made a HUGE difference. I have both kartboy bushings and I can agree that there is a big difference between the stockers and these. Less so on the rear bushing. But if you have ever held the front bushing you can tell how soft it is compared to the new one. Link to comment Share on other sites More sharing options...
heferly Posted July 28, 2010 Share Posted July 28, 2010 ^thanks! sp3c7r3, what kind of mods did you have to do for the mode racing sts? just the plate? anyone else have the mode sts?? looks like a good deal for a dasts sometimes you eat the bar, and sometimes...well, he eats you Link to comment Share on other sites More sharing options...
eldiablo Posted July 28, 2010 Share Posted July 28, 2010 I like the feel of stock bushings with the kartboy sts. I like the short throws, but don't like shifts which feel too "notchy". My VB Garage... Pumping the air back into despair Link to comment Share on other sites More sharing options...
SpecBGuy Posted July 28, 2010 Share Posted July 28, 2010 i saw the front brushing install pic but any rear pics? or is it easy like plug and play that theres no need for pics? Link to comment Share on other sites More sharing options...
heferly Posted July 28, 2010 Share Posted July 28, 2010 http://legacygt.com/forums/showthread.php/kartboy-rear-shifter-bushing-13313.html?t=13313&highlight=KARTBOY+REAR+BUSHING sometimes you eat the bar, and sometimes...well, he eats you Link to comment Share on other sites More sharing options...
SpecBGuy Posted July 28, 2010 Share Posted July 28, 2010 http://legacygt.com/forums/showthread.php/kartboy-rear-shifter-bushing-13313.html?t=13313&highlight=KARTBOY+REAR+BUSHING link not working Link to comment Share on other sites More sharing options...
heferly Posted July 28, 2010 Share Posted July 28, 2010 hmmm...works w/copy and paste... try again? http://legacygt.com/forums/showthread.php/kartboy-rear-shifter-bushing-13313.html?p=200865#poststop sometimes you eat the bar, and sometimes...well, he eats you Link to comment Share on other sites More sharing options...
demo243 Posted July 30, 2010 Share Posted July 30, 2010 Just installed my AVO STS. Unfortunately I only have about 2 miles on it, for the test drive to make sure everything was working right. But so far very happy. Got it second hand from another member here, but it was in almost perfect shape. Install was simple, took about 30 mins or so under the two dome lights and a flash light, had to do it this evening and ran out of light. There is a KB install walk-through on here somewhere which gives you more then enough info. As for the shifter, didnt drop it too much, I was expecting more drop, but definitely shorten the throws. It takes a little more effort, but I like it, it is a smooth effort not a rough one. Well see time will tell, but from what I read alot of people hate them at first, were as I am very happy with it from the get go. Too bad such a cool looking piece has to be hidden under the boot. Link to comment Share on other sites More sharing options...
Chameleon Posted July 31, 2010 Author Share Posted July 31, 2010 Too bad such a cool looking piece has to be hidden under the boot. i can definitely agree with you there Link to comment Share on other sites More sharing options...
