D-Boogie Posted July 12, 2010 Share Posted July 12, 2010 Im putting in an aftermarket radio and when i try to play it it wont turn on all the fuses and everything are good it just seems like the switched wire for the radio is not getting any current. So is there anything that I can do to hook up that switched wire anywhere else inside the car? Like a Cigarette Lighter? Link to comment Share on other sites More sharing options...
subikid90 Posted July 13, 2010 Share Posted July 13, 2010 Did you check to see if you have power with a tester? Are you sure you are using the right hot wire, there is one for constant hot and one for illumination lights -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
D-Boogie Posted July 13, 2010 Author Share Posted July 13, 2010 no but when i hooked the switched wire to the yellow it works now i just have to turn it off manually! But thanks Link to comment Share on other sites More sharing options...
whos_that_guy Posted July 13, 2010 Share Posted July 13, 2010 check the fuse in the engine bay >.> mine blew when i put my radio in Link to comment Share on other sites More sharing options...
D-Boogie Posted July 14, 2010 Author Share Posted July 14, 2010 alright ill try that! Link to comment Share on other sites More sharing options...
