zuczek Posted July 12, 2010 Share Posted July 12, 2010 Do I want to match my front coilover measurements so that they both have the same pre-load and same ride height adjustment or should I be setting the pre-load the same but adjusting the ride height to make sure the car has equal wheel gap? If I set them to be the same measurements for ride height, it seems like one side is slightly lower than the other and the car is on a level surface.. Same thing in the back.. If ride height measurement on the coilovers is the same, one side has more wheel gap than the other side. (Pre-load is set the same on both sides) Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted July 12, 2010 Share Posted July 12, 2010 Totally NOT trying to be a smartass but are you driving around the block and driving both forward and backward? When I set my coils I have to move the car quite a bit and go both forward and back as well as over a bump to get it all to settle perfectly. My street is not totally level so I have to take multiple measurements... Its it not perfect but I went for same wheel gap in front and back with the front end more dampened than the back. My way not the way, just a reflection on my personal experience with my KW2 Link to comment Share on other sites More sharing options...
