6speedZ Posted July 11, 2010 Share Posted July 11, 2010 I just picked up my 2010 Legacy 2.5i Premium last night and today I ran the wires to hardwire my V1 and I cant find a spot to attach the ground wire. I ran the wires under the headliner and behind the A Pillar to the fuse box and it looks pretty good, but the ground wire is only aboout 7-8 inches and everything under the dash is plastic. Any ideas? Thanks! Link to comment Share on other sites More sharing options...
King08 Posted July 11, 2010 Share Posted July 11, 2010 I grounded mine on the door hinge bolt. Works just fine. Link to comment Share on other sites More sharing options...
nemo Posted July 11, 2010 Share Posted July 11, 2010 Where are you mounting it? The car is pre-wired for the home-link mirror, so there is a connector above the map lights. You can just use that for power and ground. If you don't vote Trump, out, you're a bigot who hates america. Link to comment Share on other sites More sharing options...
6speedZ Posted July 11, 2010 Author Share Posted July 11, 2010 Where are you mounting it? The car is pre-wired for the home-link mirror, so there is a connector above the map lights. You can just use that for power and ground. I have the homelink mirror and not sure which wires to tap into. I am mounting the V1 just above the mirror. Link to comment Share on other sites More sharing options...
TSiWRX Posted July 11, 2010 Share Posted July 11, 2010 ^ Best bet is that location, just like nemo said. Unfortunately, without a '10, I'm of little help on the exact tap - but generally: You'll want to be sure you take power from an uninterrupted 12V+, since the autodmming will make the detector cut-out on you otherwise (i.e. "Reverse" engaged). Other than that, your best bet to finding which wires are for what would be either a test-light or multimeter. If you're not electronically savvy, though, I'd see about asking MikeNH for some help, as he authored this excellent thread for the BMs: http://legacygt.com/forums/showthread.php/installing-auto-dim-mirror-2010-legacy-134651.html?t=134651 And failing there, to see about others on this thread: http://legacygt.com/forums/showthread.php/auto-dimming-homelink-mirror-134050.html?t=134050&highlight=homelink Best of luck! <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
nemo Posted July 12, 2010 Share Posted July 12, 2010 check this thread: http://legacygt.com/forums/showthread.php/easy-radar-detector-install-45289p2.html?&highlight=radar it's for an 09 but i'm sure it's very similar for 2010 If you don't vote Trump, out, you're a bigot who hates america. Link to comment Share on other sites More sharing options...
TSiWRX Posted July 12, 2010 Share Posted July 12, 2010 ^ Good spot, nemo (post number 52, by my long-time brother TPLGT, as well as nemo's own contribution in the following post, as well as posts #57 and 62, for those of you who are trying to find it ) ! I'd embarrassingly totally forgot about the detail in that thread, despite having bookmarked it earlier! Indeed, the only worry that comes to my mind is how similar - or different - the two may or may not be. Hopefully, Subaru got cheap on this one, and didn't change anything! <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
nemo Posted July 12, 2010 Share Posted July 12, 2010 ^ I doubt it's changed much. Either way, there is absolutely a connector up there since the car is pre-wired for the homelink mirror. You just have to find it. When you do, just take a multi-meter and get the correct pins and use those. You're done. If you don't vote Trump, out, you're a bigot who hates america. Link to comment Share on other sites More sharing options...
TSiWRX Posted July 12, 2010 Share Posted July 12, 2010 ^ I doubt it's changed much. That's my hope, too....but we've even seen differences in wiring color within the same MY on our vehicles, so anything goes! Either way, there is absolutely a connector up there since the car is pre-wired for the homelink mirror. You just have to find it. When you do, just take a multi-meter and get the correct pins and use those. You're done. +1. The presence of the connectors on the BM-chassis is verified by MikeNH's contributions. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
