NORULZleggy Posted July 9, 2010 Share Posted July 9, 2010 Does DBA make front rotors for our 2.5i, I thought they did, but could not find them? any hep thanks Link to comment Share on other sites More sharing options...
sulk Posted July 10, 2010 Share Posted July 10, 2010 Yes they do http://www.tirerack.com/brakes/results.jsp?autoMake=Subaru&autoModel=Legacy+Wagon+2.5I&autoYear=2005&autoModClar=Base+Model Looks like DBA 4648SL / DBA 4648SR for the fronts. About 100-120USD each. Link to comment Share on other sites More sharing options...
NORULZleggy Posted July 11, 2010 Author Share Posted July 11, 2010 there's also a difference in the 2.5i and 2.5i limited. the 2.5i is 10.8" front vented/10.6 rear solid the 2.5i limited is 11.5 front vented/10.6 rear solid the 2.5GTs (both non and limited) are 12.3 front vented/11.3 rear vented How do i know which? if I am limited or not? Link to comment Share on other sites More sharing options...
Malt Beverage Posted July 11, 2010 Share Posted July 11, 2010 do you have leather and dual electronic climate control? You can also measure your rotors. Link to comment Share on other sites More sharing options...
NORULZleggy Posted July 11, 2010 Author Share Posted July 11, 2010 no i do not it is plain jane, got me's a tape deck, ahah naw, so then I am not a limited right? Link to comment Share on other sites More sharing options...
Malt Beverage Posted July 11, 2010 Share Posted July 11, 2010 Probably, but just to be sure, punch your vin in and this will tell you: http://www.carfax.com/cfm/general_check.cfm?partner=car_q Link to comment Share on other sites More sharing options...
Malt Beverage Posted July 11, 2010 Share Posted July 11, 2010 Although carfax also says I have a DOHC... lol. The 7th character in the vin will also tell you the trim level. Link to comment Share on other sites More sharing options...
NORULZleggy Posted July 11, 2010 Author Share Posted July 11, 2010 thanks malt, I am getting the leggy some new Hawk pads and DBA slotted rotors, I can get them very cheap. Link to comment Share on other sites More sharing options...
iyalla Posted July 14, 2010 Share Posted July 14, 2010 there's also a difference in the 2.5i and 2.5i limited. the 2.5i is 10.8" front vented/10.6 rear solid the 2.5i limited is 11.5 front vented/10.6 rear solid the 2.5GTs (both non and limited) are 12.3 front vented/11.3 rear vented How do i know which? if I am limited or not? Um I'm pretty sure this is for the 2005 2.5i only. All 2.5i's from 2006- had the same 11.5 fronts regardless of if they were limiteds or not. Link to comment Share on other sites More sharing options...
sulk Posted July 15, 2010 Share Posted July 15, 2010 Um I'm pretty sure this is for the 2005 2.5i only. All 2.5i's from 2006- had the same 11.5 fronts regardless of if they were limiteds or not. You seem to be correct, Fronts went up to 11.5, rears stayed the same. Now lets hope the rotors I just got are right for my 2005 Link to comment Share on other sites More sharing options...
