WompaStompa Posted June 29, 2010 Share Posted June 29, 2010 I've been shopping around for coilovers for my 08 legacy and keep running into dead ends with the spring rates. Some say default rates are 8/6, 8 in front and 6 in rear. However I have also seen defaults of 8/8, 6/8, and others. Seems like for other Subaru models, a higher spring rate in front and lower in back is ideal. I have also found out that the stock spring rates of the legacy's is about 3.5/5.5. (lower in front). Anyone else have any idea why the legacy's are different? Or any recommendations on spring rates? Link to comment Share on other sites More sharing options...
Bolksey85 Posted June 30, 2010 Share Posted June 30, 2010 It depends on the manufacturer and the model. And even the same model can have optional spring rates. ISC's can be had with (I think) 8k/6k or 10k/8k. Flex's are 10k/8k I think while BC's might be 8k/7k or 8/8. The Legacy just doesn't have the market that the WRX/STi does so we get more generic all-around choices while popular models get much more varied options because there's a market for it. And as far as what's a good rate, it depends on what you want to do. For DD and occasional auto-x or road race use, something in the 6k/8k to 8k/8k range is fine. If you do more hardcore use, stepping up to a 10K/8K might be a smart idea. Just be sure you know the compromises with higher spring rates. Link to comment Share on other sites More sharing options...
WompaStompa Posted July 1, 2010 Author Share Posted July 1, 2010 Thanks. Yeah I was thinking in the 8/7-8/8 range. I wouldn't really have a need for anything higher, also dont want to break my ass when driving on rough roads haha Link to comment Share on other sites More sharing options...
