Stang70Fastback Posted June 28, 2010 Share Posted June 28, 2010 I've figured everything out with regards to how I want to wire up my Hellas but I was hoping someone could point me to the relay for the stock horns so that I could splice in just ahead of where it receives the signal from the horn button on the steering wheel. I can't trace the wires from the stock horns obviously because those disappear into a big bundle of wires in the fender. Is this relay something I could easily find? Link to comment Share on other sites More sharing options...
rasrx7 Posted June 29, 2010 Share Posted June 29, 2010 are you planning to replace your stock horns? Why not just tap in where the stock horn is right behind the headlight under the airbox inlet pipe? That where i put my matsuba horn in. bolted up right where the stock horn was. plug and play with a relay. Link to comment Share on other sites More sharing options...
Stang70Fastback Posted June 30, 2010 Author Share Posted June 30, 2010 Alright all done, lol. Yeah I ended up unplugging the horns, putting them on a separate relay circuit and sent the original power to the horns into the car to a switch so I can select whether the horn button on the wheel honks the stock horns or my air horns. It's FRIGGIN' AWESOME! Link to comment Share on other sites More sharing options...
