SF101MN Posted June 28, 2010 Share Posted June 28, 2010 Call me what you will, I do know my way around performance vehicles, more along the lines of the two-wheeled variety though. I am trying to determine whether or not my 2005 LGT Limited is a Spec B or not. Easy to tell? I'm not sure. I need to order OEM replacement shocks. As much as I want Biltstein's, I am on a budget. KYB should work, but I don't know if there are better options, or even if my GT is a Spec B. I already made a mistake of buying some 19's with 235 x 35 tires that don't fit. HELP! Link to comment Share on other sites More sharing options...
naaz90 Posted June 28, 2010 Share Posted June 28, 2010 Call me what you will, I do know my way around performance vehicles, more along the lines of the two-wheeled variety though. I am trying to determine whether or not my 2005 LGT Limited is a Spec B or not. Easy to tell? I'm not sure. I need to order OEM replacement shocks. As much as I want Biltstein's, I am on a budget. KYB should work, but I don't know if there are better options, or even if my GT is a Spec B. I already made a mistake of buying some 19's with 235 x 35 tires that don't fit. HELP! Spec B is '06+ Link to comment Share on other sites More sharing options...
Drift Motion Posted June 29, 2010 Share Posted June 29, 2010 05, no 6 speed = non spec b i just put on coils on my LGT...hahaha Link to comment Share on other sites More sharing options...
SF101MN Posted June 29, 2010 Author Share Posted June 29, 2010 Thanks for the posts! Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted June 29, 2010 Share Posted June 29, 2010 SF you should check out cars101.com. Great subaru info resource. Will help save you from embarassing questions Link to comment Share on other sites More sharing options...
