rSTimpreza Posted June 28, 2010 Share Posted June 28, 2010 I have a 1998 legacy wagon 2.5 recently the temperature goes up when im on dead stop and I have to rev the engine then temp goes down so basically when i'm driving its in normal temp. I dont know where to start the diagnose the problem. Any help will be greatly appreciate. Link to comment Share on other sites More sharing options...
teh luckinator Posted June 28, 2010 Share Posted June 28, 2010 I'd say check coolant level first, and then check if your fans are functioning. Link to comment Share on other sites More sharing options...
subikid90 Posted June 28, 2010 Share Posted June 28, 2010 I'd say check coolant level first, and then check if your fans are functioning. + thermostat, water pump or leaks -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
rSTimpreza Posted July 4, 2010 Author Share Posted July 4, 2010 Fixed the problem it was the thermostat found out the old wasn't oem part. Replaced it with a new oem part so far been driving the car and no more temp spiking up Link to comment Share on other sites More sharing options...
Reuben Posted July 5, 2010 Share Posted July 5, 2010 Aaaaaaalways use genuine parts. Sooooo many water pumps and thermostats i have replaced that were crappy aftermarket and had crapped out. Link to comment Share on other sites More sharing options...
