ssbtech Posted May 13, 2015 Share Posted May 13, 2015 I have read all the comments and it appears they will fit HOWEVER will my stock outback tyres 215/55/17 still fit with the new shocks? Based on successful conversions in North America, I'd say they'll fit. It's close, but they'll fit. I have Legacy Bilstein HD struts on my car with 225/55/17 tires. Link to comment Share on other sites More sharing options...
lowndes8 Posted May 13, 2015 Share Posted May 13, 2015 Great new tyre's still have tread left on them so maybe when my next set is due i will go down slightly in size Link to comment Share on other sites More sharing options...
lowndes8 Posted June 9, 2015 Share Posted June 9, 2015 Ok heres mine Some advice. I found the legacy GT springs in the rear too soft the car would bounce over every single bump so im going to replace them with the stock outback springs and they have a extra coil compared to the legacy springs. Should raise the rear 10-15mm. Will post pics when done http://i60.tinypic.com/6roeg1.jpg http://i59.tinypic.com/2ngzm9j.jpg Link to comment Share on other sites More sharing options...
N.Y.X. Posted June 9, 2015 Share Posted June 9, 2015 ^^Looks good!! Here's my swap I recently finished; '08 OBXT Before: http://i1063.photobucket.com/albums/t503/childreth13/2_zpsgo3kng0t.jpg After: Whiteline Rear Control Arm Bushing Whiteline Roll Steer Bump Correction LGT Lateral Link Assemblies LGT Rear Control Arms LGT BCBR Coilovers LGT on top, OBXT on Bottom http://i1063.photobucket.com/albums/t503/childreth13/20150522_170351_zpsaeyw7nhq.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150524_173115_zps5jpdpg6a.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150524_173126_zpsqkv2bpti.jpg Link to comment Share on other sites More sharing options...
N.Y.X. Posted June 11, 2015 Share Posted June 11, 2015 Got the alignment after the suspension swap and couldn't quite get the rear in spec. Is there any other rear camber adjustment parts that I am leaving out that could improve my alignment? Currently she is sitting at 25-3/4" F Fender height and 26-1/4" in the rear, if I go up more in the rear I know it will correct it but would be a bit too high for my liking. Opinions? '08 Ouback XT Whiteline Rear Control Arm BushingWhiteline Roll Steer Bump CorrectionLGT Lateral Link AssembliesLGT Rear Control ArmsLGT BCBR Coilovers http://i1063.photobucket.com/albums/t503/childreth13/20150611_072046_zpszzgazfjr.jpg Link to comment Share on other sites More sharing options...
whitetiger Posted June 12, 2015 Share Posted June 12, 2015 (edited) that alignment is crap. you left with a thrust angle that is not absolute 0. BTW just cause its red, does not met its not in "spec". these cars need more negative camber, around -1.5 each side for daily driving. So at around -1.2 for you is fine. they just should have tried harder to get the sides equal. Id be more concerned with rear toe not being equal. Id go back and demand they get front and rear toe equal on both sides to the .0001. If you get the whiteline KTA124, it will make achieving a good alignment much easier. Edited July 13, 2015 by whitetiger Link to comment Share on other sites More sharing options...
lim jahey Posted July 13, 2015 Share Posted July 13, 2015 Looks great man ! I'm doing mine this weekend all I need is the lgt bumpstops?, Sent from my Z936L using Tapatalk Link to comment Share on other sites More sharing options...
gto7419 Posted July 29, 2015 Share Posted July 29, 2015 Are the lgt bumps smaller? Previous owner lowered my obxt and the rear upper control arms were not changed. I have about 1-2" of travel between the arm and the bumps. Im buying LGT arms as I type this. Will also buy the whiteline kit Link to comment Share on other sites More sharing options...
lowndes8 Posted July 31, 2015 Share Posted July 31, 2015 Yes they are around half the size Link to comment Share on other sites More sharing options...
lowndes8 Posted July 31, 2015 Share Posted July 31, 2015 Just any update on my outback. So i had the Spec B Bilstein's in there and personally found them too hard. I have since sourced a stock set of legacy wagon shocks/springs and its much nicer. Link to comment Share on other sites More sharing options...
TiagoSantos Posted October 28, 2015 Share Posted October 28, 2015 Just did the swap last weekend. Legacy GT struts and springs, rear upper control arms and bump stops onto the OBXT. Had it aligned today and everything checked out except the rear toe - they could only get it to 0.35deg per side! I believe the spec is -0.1 to 0 per side. A positive angle on rear toe means toe out, correct? Is there an easier fix for getting toe back in spec than spending +$400 on the KTA124 kit? Rear camber is perfect, just toe that needs some help. Link to comment Share on other sites More sharing options...
N.Y.X. Posted October 28, 2015 Share Posted October 28, 2015 Do you have the rear whiteline control arm bushings? Link to comment Share on other sites More sharing options...
TiagoSantos Posted October 28, 2015 Share Posted October 28, 2015 You mean the outer bushing on the upper control arm - KCA399 - right? On their way, but not on the car yet. From the posts I've seen in this thread, I expected rear camber to be problematic, but not toe. Hence ordering the control arm bushings.. Then decided to just give it a try only to find out it's toe that I can't adjust to spec. Looking at the suspension geometry, it doesn't look like the whiteline bushings will affect toe that much, though.. Link to comment Share on other sites More sharing options...
eurokid Posted March 7, 2016 Share Posted March 7, 2016 ive just joined this forum specifically to post in this thread in hopes to find a better solution for the suspension for my outback. 06 outback 2.5i ive previously had the stock 185k mile suspension replaced with a good used set of tein coilovers off a legacy sedan. although fun for me for a while, it wasnt very smooth needless to say. too harsh of a ride, especially since my wife does drive this car more than i do. then i found some jdm bilsteins, they fit but i have this sag in the rear like the suspension is lower in the back than the front. i assume this set also came from a sedan. i see you all have found that legacy gt suspension fits the outbacks quite well, and im pleased to see that and it seems this is the desired setup i have been looking for. but for the life of me i cannot find the specific year and model subaru legacy that you all have sourced your parts from... can someone please shed some light on this for me? the search is exasperating:spin: Link to comment Share on other sites More sharing options...
whitetiger Posted March 7, 2016 Share Posted March 7, 2016 any 05-09 legacy takeoffs will work for you. I find it hard to believe that you could not find this easily in a search. Link to comment Share on other sites More sharing options...
dvancleve Posted March 7, 2016 Share Posted March 7, 2016 then i found some jdm bilsteins, they fit but i have this sag in the rear like the suspension is lower in the back than the front. i assume this set also came from a sedan. can someone please shed some light on this for me? the search is exasperating:spin: If everything about the Bilsteins is good except the rear sag, "saggy butt" spacers are the way to go. They just sandwich between the top of the rear shock and the body. Otherwise, you want 2005-2009 LGT wagon springs and struts/shocks. HTH, Doug Link to comment Share on other sites More sharing options...
eurokid Posted March 7, 2016 Share Posted March 7, 2016 any 05-09 legacy takeoffs will work for you. I find it hard to believe that you could not find this easily in a search. i wasnt aware that subaru had different variations of this platform (legacy gt vs outback between 05-09) and neither was my local salvage yard when i mentioned there were differences in the suspension between the two models. i assumed so after reading the thread but just wanted to be extra sure:rolleyes: If everything about the Bilsteins is good except the rear sag, "saggy butt" spacers are the way to go. They just sandwich between the top of the rear shock and the body. Otherwise, you want 2005-2009 LGT wagon springs and struts/shocks. HTH, Doug i was thinking about spacers but wasnt sure where to find a set, i love the suspension otherwise. was also considering lowering the front a bit to compensate for the rake its really god awful. Link to comment Share on other sites More sharing options...
eurokid Posted March 7, 2016 Share Posted March 7, 2016 (edited) yea so i just found a set of spacers, hmmm. thanks for pointing me in that direction..this will probably take care of it infact i think i may make some. i dont need much lift.. Edited March 7, 2016 by eurokid Link to comment Share on other sites More sharing options...
PrelateBishop Posted April 15, 2016 Share Posted April 15, 2016 Subscribed Link to comment Share on other sites More sharing options...
Geckoboy86 Posted April 21, 2016 Share Posted April 21, 2016 Just lowered my Outback Sedan 3.0R on a set of LGT suspension. All that was swapped was the complete struts. Looks amazing but my front right is rubbing under load. Link to comment Share on other sites More sharing options...
WellsMcKenzie Posted June 2, 2016 Share Posted June 2, 2016 Just bit the bullet and I have KYB front and rear struts, new bumpstops and mounts, some new tools, springs, control arms, bumpstops, whiteline camber kit, and 1/2" spacers + longer bolts on the way. All the parts are brand new, either from amazon (KYB) or Subaru directly. I don't think I've really seen anyone say they have gone with all new parts yet. So excited to get off this near 100,000 mile stock outback suspension.http://i.imgur.com/7zrrH3g.jpg Link to comment Share on other sites More sharing options...
WellsMcKenzie Posted June 7, 2016 Share Posted June 7, 2016 So I was able to swap all the new parts in, except for the rear LGT control arms. The bolt and nut are so stuck that I broke my breaker bar on it. Also there is no leverage to get that thing out. I guess I need to rear sway bar off or something. Anywho, the car is lowered, all the parts were brand new, and I couldn't be happier with the ride. Here is the final ride http://i.imgur.com/3RkDKjQ.jpg And all the before and after pics. (some didn't come out as well as expected because of the harsh sunlight) http://i.imgur.com/70WD9CP.jpg http://i.imgur.com/ckcZDjn.jpg http://i.imgur.com/whXCxsP.jpg http://i.imgur.com/rqrcEQv.jpg http://i.imgur.com/grJx8VJ.jpg http://i.imgur.com/cjWMUSo.jpg http://i.imgur.com/v4fmMKU.jpg Link to comment Share on other sites More sharing options...
mtruffat Posted June 8, 2016 Share Posted June 8, 2016 very cool, I just got an 06 XT and I am thinking about doing this mod pretty soon. How much did this set you back if you don't mind me asking. Link to comment Share on other sites More sharing options...
WellsMcKenzie Posted June 8, 2016 Share Posted June 8, 2016 very cool, I just got an 06 XT and I am thinking about doing this mod pretty soon. How much did this set you back if you don't mind me asking. With all new parts, half sourced from Amazon, half sourced from subaruparts.com, I spent about $1200. Parts list includes, springs, struts, control arms, bumpstops, strut boots, control arm bushings, strut mounts, rear spacers, and some new tools. I haven't replaced the control arms yet because I can't get them off. So that price doesn't include my alignment because I can't get one yet. Total I will probably have spent a little over 1300. But man, after driving it to work, and a little spirited driving after work, it was worth every dime. It looks perfect to me and it handles 20 times better than my blown outback struts. Sent from my SAMSUNG-SM-G890A using Tapatalk Link to comment Share on other sites More sharing options...
mtruffat Posted June 8, 2016 Share Posted June 8, 2016 With all new parts, half sourced from Amazon, half sourced from subaruparts.com, I spent about $1200. Parts list includes, springs, struts, control arms, bumpstops, strut boots, control arm bushings, strut mounts, rear spacers, and some new tools. I haven't replaced the control arms yet because I can't get them off. So that price doesn't include my alignment because I can't get one yet. Total I will probably have spent a little over 1300. But man, after driving it to work, and a little spirited driving after work, it was worth every dime. It looks perfect to me and it handles 20 times better than my blown outback struts. Sent from my SAMSUNG-SM-G890A using Tapatalk Cool thanks for the info, that will be helpful to plan Link to comment Share on other sites More sharing options...
