whitetiger Posted September 2, 2013 Share Posted September 2, 2013 so ive been playing around with this and installed spec.b take-offs on my OB. the rear ended up sitting perfect, but for some reason the front was way way too low. was rubbing on some turns(tire to fender). So just as a trial, i threw the OB springs on the spec b shocks and now the the front is too high, almost at stock Outback ride height. Im thinking maybe regular LGT springs will split the difference, but there is only one way to find out. here is what it looked like with the spec b springs in front Link to comment Share on other sites More sharing options...
Sideways the Seven Posted September 3, 2013 Share Posted September 3, 2013 Interesting. That's a lot lower than I expected. Sent from my SGH-T699 using Tapatalk 2 -Brandon 2007 Chevrolet Suburban LT3 1981 Chevrolet C10 LWB Link to comment Share on other sites More sharing options...
whitetiger Posted September 7, 2013 Share Posted September 7, 2013 Alright, just swapped in GT springs in place of the spec.b springs in the front on the Bils and the ride height is now perfect. completely even from front to back with just about 2 fingers worth of fender gap. Link to comment Share on other sites More sharing options...
ssbtech Posted September 7, 2013 Share Posted September 7, 2013 Aren't the USDM Spec B springs the same as the GT springs? Link to comment Share on other sites More sharing options...
whitetiger Posted September 7, 2013 Share Posted September 7, 2013 no, they are shorter to accommodate the higher lower perch on the front bilstein shocks. Link to comment Share on other sites More sharing options...
Impatient Posted September 8, 2013 Share Posted September 8, 2013 Admittedly, the springs I saw we're used, and might not have been as advertised, but the front spec B springs were much longer than LGT (at least as long as OB XT) and thinner gauge. I never mounted them, but had the impression they would result in higher ride height than LGT mounted on the same strut. But maybe they would sag more given the thinner gauge. This was always baffling to me given spec B allegedly being higher perf. Maybe softer spring mates better with Bilstein, IDK. Link to comment Share on other sites More sharing options...
whitetiger Posted September 9, 2013 Share Posted September 9, 2013 spec b springs def are thinner gauge compared to lgt springs. didnt really compare the height, but the spec b springs def compressed more than lgt springs. so it could be that and not the uncompressed height as you said. either way, they did the trick. Link to comment Share on other sites More sharing options...
BAC5.2 Posted September 9, 2013 Share Posted September 9, 2013 Admittedly, the springs I saw we're used, and might not have been as advertised, but the front spec B springs were much longer than LGT (at least as long as OB XT) and thinner gauge. I never mounted them, but had the impression they would result in higher ride height than LGT mounted on the same strut. But maybe they would sag more given the thinner gauge. This was always baffling to me given spec B allegedly being higher perf. Maybe softer spring mates better with Bilstein, IDK. Stiffer doesn't always mean better performance. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
drunkinmonk Posted September 14, 2013 Share Posted September 14, 2013 I purchased used legacy gt sedan shocks and strut assembly. Does anyone have pictures with and without saggy butt spacers? I'm curious how much difference they are compared to the lgt wagon for the rears. I believe the front ones sedan/wagon are the same. Link to comment Share on other sites More sharing options...
MichaelBrown86 Posted January 1, 2014 Share Posted January 1, 2014 So, if I buy LGT shocks/struts and lowering springs, what else will I need? What is the name of that rubber piece between the spring and shock tower? What's that even called? Can I reuse my XT ones? Link to comment Share on other sites More sharing options...
ssbtech Posted January 1, 2014 Share Posted January 1, 2014 Yes, you can re-use the XT's upper spring perch and upper mount. How low are you trying to go? Link to comment Share on other sites More sharing options...
MichaelBrown86 Posted January 1, 2014 Share Posted January 1, 2014 (edited) Yes, you can re-use the XT's upper spring perch and upper mount. How low are you trying to go? H&R springs offer a 1.5-2.0 inch drop. So, along with the struts, probably 3-4 inches total? I'm basically trying to have the ride-height of a lowered legacy, not a lowered outback. Does that makes sense? Edited January 1, 2014 by MichaelBrown86 Link to comment Share on other sites More sharing options...
bighayden Posted February 19, 2014 Share Posted February 19, 2014 how is the sway bar doing? did you have to change the sway bar end links? didn't know if youd get any unwanted contact or too much added stress. really wanna do this mod. looks great though! Link to comment Share on other sites More sharing options...
amfloyd79yahoo.com Posted March 20, 2014 Share Posted March 20, 2014 did the same swap yesterday and the back end is sagging 2-3" and my rear wheel camber is -3 to 4 degrees. Anyone have any suggestions??? used 06 lgt wagon shocks. Link to comment Share on other sites More sharing options...
ssbtech Posted March 20, 2014 Share Posted March 20, 2014 Big spacers. Link to comment Share on other sites More sharing options...
Vagetarian Posted September 24, 2014 Share Posted September 24, 2014 Reviving dead thread! I've got kyb legacy front and read struts ordered from rockauto. I plan on just cutting down my bump stops instead of replacing them. Any problems with this? Also can someone tell me if I can carry over my stock strut boot cover from my obxt when I do the swap or will I need to order legacy specific ones? Link to comment Share on other sites More sharing options...
WellsMcKenzie Posted November 8, 2014 Share Posted November 8, 2014 Reviving dead thread! I've got kyb legacy front and read struts ordered from rockauto. I plan on just cutting down my bump stops instead of replacing them. Any problems with this? Also can someone tell me if I can carry over my stock strut boot cover from my obxt when I do the swap or will I need to order legacy specific ones? Did you ever install everything? I actually had the questions run through my head as I was looking into the KYB Legacy GT struts and wasn't sure about the strut covers. Link to comment Share on other sites More sharing options...
Vagetarian Posted November 8, 2014 Share Posted November 8, 2014 I did do the install. You can cut down the bump stops just fine. I cut the stops in half on the front strut and the bump stops in the rear in half as well. The stock boot works great. Only thing I'm not happy about is the 3/8" spacer I went with. Still a little bit of sag in the rear. Going to change out for 1/2" or maybe even 3/4" for a bit of rake. Link to comment Share on other sites More sharing options...
drunkinmonk Posted November 9, 2014 Share Posted November 9, 2014 I had way to much sag in the rear. I ended putting back the stock outback rear set up and legacy front. Nice muscle car stance. Big rake. Link to comment Share on other sites More sharing options...
Vagetarian Posted November 10, 2014 Share Posted November 10, 2014 Post some pictures! Here's mine : http://tapatalk.imageshack.com/v2/14/11/09/970feb18db225a64659dce62bafa59fb.jpg Link to comment Share on other sites More sharing options...
Rhitter Posted November 10, 2014 Share Posted November 10, 2014 Looks good. Won't be able to go off road like you used to anymore though.. My OBXT build Link to comment Share on other sites More sharing options...
Vagetarian Posted November 10, 2014 Share Posted November 10, 2014 It's ok that's what trucks for Link to comment Share on other sites More sharing options...
Vagetarian Posted November 24, 2014 Share Posted November 24, 2014 I've had the sedan suspension swapped into my obxt for a couple months now but yesterday I just got around to measuring the distance between my tire and wheel well. I was surprised to find a 1" difference between the front and the back. The back sagging that much even with a 3/8" spacer. Do you guys think this could be from installing the springs improperly? I've noticed an annoying clunk noise on the rear whenever I hit bumps or potholes. To me it almost sounds and feels like I'm hitting the bump stops but upon inspection ot looks like I've got plenty of clearance. (cut my stock stops in half). Anyone else experience anything like this? Hardware: New Kyb struts 100,00 mile used LGT sedan Springs 3/8" saggy butt spacers Link to comment Share on other sites More sharing options...
Rhitter Posted November 24, 2014 Share Posted November 24, 2014 I've had the sedan suspension swapped into my obxt for a couple months now but yesterday I just got around to measuring the distance between my tire and wheel well. I was surprised to find a 1" difference between the front and the back. The back sagging that much even with a 3/8" spacer. Do you guys think this could be from installing the springs improperly? I've noticed an annoying clunk noise on the rear whenever I hit bumps or potholes. To me it almost sounds and feels like I'm hitting the bump stops but upon inspection ot looks like I've got plenty of clearance. (cut my stock stops in half). Anyone else experience anything like this? Hardware: New Kyb struts 100,00 mile used LGT sedan Springs 3/8" saggy butt spacers Did you replace all the rubber bits? Spring seats and spring perches? I think usually for wagons peope are running 1/2 - 3/4 inch spacers to even it all out. My OBXT build Link to comment Share on other sites More sharing options...
Vagetarian Posted November 24, 2014 Share Posted November 24, 2014 No, everything I replaced I listed above. Would be happy to know I could fix my problem with just adding a bigger spacer. The clunking has me a little worried though. Link to comment Share on other sites More sharing options...
