daddywagon Posted June 20, 2010 Share Posted June 20, 2010 so my abs light came on, horn quit, a/c wont blow and stoplights do not work. i dont see how they can all be related but, they all came on, than went off and everything worked. now they are not working again please help. Link to comment Share on other sites More sharing options...
subikid90 Posted June 21, 2010 Share Posted June 21, 2010 Under the dash on your drivers side against the side wall there is a black box with fuses and also another one in your engine bay by the battery. I know for a fact the horn relay is in the engine fuse box. The other problems may or may not have a fuse associated with them but check all of them first to be sure. I have a feeling they are not all tied together. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
daddywagon Posted June 21, 2010 Author Share Posted June 21, 2010 the fuse is good. i have power to all fuses. Link to comment Share on other sites More sharing options...
subikid90 Posted June 21, 2010 Share Posted June 21, 2010 Did you check the horn relay? Switch it with another relay in the box that you know works. The others have me stumped. Maybe an alternator? I have heard they cause some crazy issues when they are going bad. Worth checking it really quick. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
daddywagon Posted June 22, 2010 Author Share Posted June 22, 2010 ok so everything worked yesterday for a little bit. i took my wife and kids swimming everything is fine. get back to the car after swimming nothing. go to work today nothing, come home for lunch they all work again. it is really sporradic. what to do now? Link to comment Share on other sites More sharing options...
mwiener2 Posted June 22, 2010 Share Posted June 22, 2010 you have a connector that has gotten moisture in it and is corroded you need to find which connector it is and clean it. good luck My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
