Kw521 Posted June 20, 2010 Share Posted June 20, 2010 My car is getting a few goodies put on here in a little bit. Ditching my spt intake for a cobb one....getting a dn-pipe up-pipe gt spec uel headers and a pro tune.....im keeping the stock turbo for now. Now I dont have a whole lot of knowledge about inter coolers(just the basic stuff). Will and aftermarket tmic benefit me more with all the said mods and the tune on the car or will it make no difference be it that i still have the stock turbo Link to comment Share on other sites More sharing options...
peteyjr Posted June 20, 2010 Share Posted June 20, 2010 I upgraded to an AVO intercooler and it definitely helped . Since you are getting a protune and it is needed to maximize the intercooler you are good to go. They are expensive but can often be had for around $ 500 used. I've heard of Perrins new can go for 500-600. Can't prove it dynowise but the butt dyno showed a likely 5-8 hp difference and a deeper well or torque. Also really helped lower heat soak on those hot days. Very worth it IMO Link to comment Share on other sites More sharing options...
gk1 Posted June 21, 2010 Share Posted June 21, 2010 OEM TMIC doesn't have reliable integrity at higher-than-stock boost, so with pipes and tune, an aftermarket intercooler will potentially help reliability at your increased boost, too. Link to comment Share on other sites More sharing options...
Kw521 Posted June 21, 2010 Author Share Posted June 21, 2010 ive considered a better tmic...im just curious will i make more power with it? and will it be a more efficient power I.E. holding boots faster spool etc etc Link to comment Share on other sites More sharing options...
biz77 Posted June 21, 2010 Share Posted June 21, 2010 I doubt you'll see any significant increase in power over the stocker, but FWIW I blew my stocker apart within a day of running 18psi at stage two. As a minimum, I recommend JB welding your end tanks before running stage II boost levels. Link to comment Share on other sites More sharing options...
