WagSubGTL Posted June 11, 2010 Share Posted June 11, 2010 My car went into limp mode when my turbo blew and now i put a new one in and i cant get it out of limp mode!!!! It's throwing me tps codes with the check engine light on and cruise blinking. I tried disconnecting the battery that doesnt work tried turning the key on and pumping the brakes 5 times that didnt work please someone fill me in.. someone said that it might be that only subaru can reset it with their subaru comps. Link to comment Share on other sites More sharing options...
ehsnils Posted June 12, 2010 Share Posted June 12, 2010 You can reset the codes with an ordinary code reader or remove the battery cable, push the brake pedal for a minute (not pump, just press) with ignition on, then take a break of 20 minutes and go back. And if you still get the codes post the actual codes. Purchasing a code reader is a good idea. Also see this thread: http://legacygt.com/forums/showthread.php/2-5gt-turbo-oil-supply-banjo-bolt-filter-removal-61689p41.html Link to comment Share on other sites More sharing options...
WagSubGTL Posted June 12, 2010 Author Share Posted June 12, 2010 tried all that and just took banjo out while replacing turbo Link to comment Share on other sites More sharing options...
WagSubGTL Posted June 12, 2010 Author Share Posted June 12, 2010 Ttt Link to comment Share on other sites More sharing options...
WagSubGTL Posted June 12, 2010 Author Share Posted June 12, 2010 Update: Hooked it up to a Subaru computer still couldn't pull the codes.... P2109 Tps sensor minimum performance is the code.. I pulled all the relays under the dash, they are all fine. I am going to replace the tps sensor monday see if that works.. any one have similar problems. Link to comment Share on other sites More sharing options...
clarkwgriswold Posted June 12, 2010 Share Posted June 12, 2010 You might want to get some Viagra and put it in the gas tank. Link to comment Share on other sites More sharing options...
ehsnils Posted June 12, 2010 Share Posted June 12, 2010 Update: Hooked it up to a Subaru computer still couldn't pull the codes.... P2109 Tps sensor minimum performance is the code.. I pulled all the relays under the dash, they are all fine. I am going to replace the tps sensor monday see if that works.. any one have similar problems. When you are doing that also check that the throttle isn't sticking in some way. The code indicates that the opening of the throttle isn't what the ECU expects, and that can be due to a sensor fault, motor fault or something sticking. Link to comment Share on other sites More sharing options...
Dntk Posted June 12, 2010 Share Posted June 12, 2010 My 09 LGT did that when i overboosted (stupid Invidia wastegate divider) i disconnected the battery for the night and reconnected it the next day, went back to normal, on a seperate occasion i just used my tactrix 2.0 and learning view and hit "reset ecu" worked as well, however the way you describe the persistence of yours im not sure if that will help Link to comment Share on other sites More sharing options...
WagSubGTL Posted June 12, 2010 Author Share Posted June 12, 2010 thanks for your insight guys. Link to comment Share on other sites More sharing options...
WagSubGTL Posted June 13, 2010 Author Share Posted June 13, 2010 Ttt Link to comment Share on other sites More sharing options...
WagSubGTL Posted June 14, 2010 Author Share Posted June 14, 2010 ttt Link to comment Share on other sites More sharing options...
