Dntk Posted June 4, 2010 Share Posted June 4, 2010 I recently put on an Invidia DP with the big ole divider thing in the middle, and got some major over boosting, so i took it off to grind it down, but the divider was dented pretty good, and its a decently thick piece of solid metal, so i was wondering if the piece in the turbo (wastegate door/cap thing? right?) hitting the divider hard enough to dent it could have damaged it? i grinded it down and the car runs normally again, but if anyone has had any experience with the same thing I'd like to know what happened with yours, Thanks. Link to comment Share on other sites More sharing options...
m sprank Posted June 4, 2010 Share Posted June 4, 2010 If it is running fine... You looked at the flapper right? Was it visibly damaged? Is it holding boost? If so, sounds ok. Link to comment Share on other sites More sharing options...
Dntk Posted June 5, 2010 Author Share Posted June 5, 2010 Yeah everything is running fine, i'm deploying soon so im trying to make sure the car is going to be ok for the wif to drive while im gone, id hate to break it right before i leave Link to comment Share on other sites More sharing options...
GTTuner Posted June 5, 2010 Share Posted June 5, 2010 I must note to anyone installing one of these pipes on anything but a VF40 to chk for interference before installing. Link to comment Share on other sites More sharing options...
