BAC5.2 Posted June 7, 2010 Author Share Posted June 7, 2010 Great info Leke! Thanks! Any idea if the EDM cars were available with the same wood trim as the USDM models? [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Leke Posted June 7, 2010 Share Posted June 7, 2010 I'm not completely sure. I've seen pictures floating around with the wood grain, but I'm not sure if they're aftermarket or not. I've always hated the wood grain, so I'd be using the opportunity to switch to the silver trim. Link to comment Share on other sites More sharing options...
BAC5.2 Posted June 7, 2010 Author Share Posted June 7, 2010 Are you going to go through with the swap? I'll live vicariously through you to guinea pig it, then consider pulling the trigger after seeing the results. I'm mostly concerned with the fitment of the SI-Drive panel, and the fitment with the OEM radio. I also wish the ash-tray area was available in silver, not black. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted June 8, 2010 Share Posted June 8, 2010 But, if you'd like to double check, go to this link: http://opposedforces.com/parts/legacy/en_b13/. The link I gave you is already set to look for European specific parts. ^Great link, thanks for taking the time to post some # and the link. Interesting to check out for sure! Link to comment Share on other sites More sharing options...
Leonardo Posted June 10, 2010 Share Posted June 10, 2010 The thing I like are the black pilars on the JDM special editions. Link to comment Share on other sites More sharing options...
