Canyonero Posted June 3, 2010 Share Posted June 3, 2010 ok so im gonna be doing some basic stuff to keep the leggy up and runnin smoother. 1. I was going to use Ngk Platinum spark plugs along with Oreilly/kragen oem wires. (any other reccomendations.) 2. Transmission fluid? was going to just use some brand name havent decided yet. 3. ignition coil should be changed at what point? does it matter its the same one runnin on 205k miles? Link to comment Share on other sites More sharing options...
Reuben Posted June 3, 2010 Share Posted June 3, 2010 1. Sounds good. 2. Sweet 3. Never? Replace it.... when it dies. Link to comment Share on other sites More sharing options...
Bassnectar Posted June 3, 2010 Share Posted June 3, 2010 Ngk wires are suppost to be a lil better than oem and not much more 2. i would do research on the tranny fluid as you cant just go putting the newest synthetics in older cars as it can mess with the synchro - manuals if it is to lubricated (sorry i dont have answer) 3 and unless you have a misfire thats unresolvable by plugs and wires and other basic stuff then maybe but otherwise leave it Link to comment Share on other sites More sharing options...
Canyonero Posted June 3, 2010 Author Share Posted June 3, 2010 ic ok. Anything else i should add to my list today? Link to comment Share on other sites More sharing options...
Bassnectar Posted June 4, 2010 Share Posted June 4, 2010 change the fuel filter, check its date though to see how old it is. keep up on oil changes!! but what else have you done? I changed my rear diff fluid to synthetic and i feel like its made a slight improvement is your car auto or manual?? if manual and your changing, fill the rear diff with the same fluid you fill the transmission with!!! it takes .9 litres so shouldnt take one full bottle of 75w 90 the slippier the synthetic the better for the rear diff, not the same for transmission though I want to get my transmission drained and filled as i dont know when its last been done!! Link to comment Share on other sites More sharing options...
legacyman1657615403 Posted June 4, 2010 Share Posted June 4, 2010 i would do NGK plugs and wires. yeah u will spend more money on ngk wires versus oreilys brand. but it sure makes a difference. Link to comment Share on other sites More sharing options...
