rockford33 Posted May 31, 2010 Share Posted May 31, 2010 Searched here and found out that you can check engine codes by connecting 2 white plugs in the fuse box area under the dash. Car had a CEL as soon as I turned it on tonight (worked fine all day and I never got gas today....). Where are the two white plugs. Everything I see is connected into plugs, nothing hanging loose. Are they just hanging loose somewhere and you have to find and connect them together? Any help appreciated. Really wish i had an AP, but with all the layoffs at my work, I'm saving my money for now.... Thanks,Neil Link to comment Share on other sites More sharing options...
rockford33 Posted May 31, 2010 Author Share Posted May 31, 2010 found the plugs, taped up in the dash. I don't think subaru really wanted you to find them. Now I get a P2004, 2005, and 2012 error code. Can't find the codes here in the forums. Is there a list somewhere? Thanks,Neil Link to comment Share on other sites More sharing options...
rockford33 Posted May 31, 2010 Author Share Posted May 31, 2010 ok, finally found the what these codes apparently mean (still haven't found a listing of codes though). Tumble valves. Is it fairly simple to just pop the intake manifold off and squirt them with some carb cleaner? Then how do I reset the codes? Haynes manual makes taking off the intake manifold look easy with just a couple of O-rings for sealing things in place. If I can pop off the intake manifold, clean the valves, and pop the manifold back on and reset the codes, I would be golden. -Neil Link to comment Share on other sites More sharing options...
OhBe1 Posted May 31, 2010 Share Posted May 31, 2010 I don't know, except I'm thinking carb cleaner would be what not to use. I know this isn't the throttle boy, but, carb cleaner there can cause issues with the lining. So I'd suggest throttle body cleaner instead. I think clearing the codes can be done by disconnecting the battery for 20 minutes or so - I think there's also a quicker method involving doing a dance with the brake pedal or some such. But it's probably time to think about an OBD2 reader/resetter, which can be had for $70 or so. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
ehsnils Posted May 31, 2010 Share Posted May 31, 2010 The tumble valves are an emission control item for emissions at idle. At least there isn't usually any risk of engine damage if they are acting up. Link to comment Share on other sites More sharing options...
Blameless Posted June 1, 2010 Share Posted June 1, 2010 Rockford33 where did you find all your info? I am also wanting to get a list of codes... Link to comment Share on other sites More sharing options...
rockford33 Posted June 1, 2010 Author Share Posted June 1, 2010 Blameless,I haven't found yet a list of all the codes. I ended up finding the codes I got by searching specifically for them on the forum. Turns out it is not an uncommon set of codes to get... Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 1, 2010 Share Posted June 1, 2010 I found this list on the forum. should be what you were looking for.. Link to comment Share on other sites More sharing options...
Blameless Posted June 2, 2010 Share Posted June 2, 2010 thats awesome! thanks... Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 2, 2010 Share Posted June 2, 2010 No problem mate. You're from New Zealand? That's cool! I am actually from Tahiti but currently living in ..... Norway Kia Ora bro. Link to comment Share on other sites More sharing options...
Blameless Posted June 2, 2010 Share Posted June 2, 2010 Hahaha! Ahhh the land of the long white cloud :-) paradise I tell you! Link to comment Share on other sites More sharing options...
rockford33 Posted June 2, 2010 Author Share Posted June 2, 2010 Cleared the codes. I had planned on removing the intake manifold and cleaning the valves, but there was too much stuff to remove to get the manifold off (and I had more pressing things to do like re-install a sink and toilet in a bathroom!). So far, no more codes. If it comes back, I guess I will go to the dealer to get it fixed, but for now everything seems to be running fine. Maybe they un-stuck themselves.... Link to comment Share on other sites More sharing options...
