Baddog Posted May 31, 2010 Share Posted May 31, 2010 So I recently flushed the transmission and filled it. I happened to get it about half an inch over the full line. Today I took some out to see if it was just so damn full because I could smell the trans fluid in the cabin after getting on it. When I had taken some out and got it at the full line just about dead on. It still has that smell. Also when I have unplugged the return line both times to flush the first time and the second time fluid came out and spilled. Could that be why I smell it after the car gets warm? I spilt a decent amount of it but cleaned it up the best I could with a towel. Link to comment Share on other sites More sharing options...
subikid90 Posted May 31, 2010 Share Posted May 31, 2010 Do u have at fluid light on? If not it could just be the spill. Do u see any leaks anywhere? -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Baddog Posted May 31, 2010 Author Share Posted May 31, 2010 No leaks. No steam and no fluid light (never knew I had one) Link to comment Share on other sites More sharing options...
subikid90 Posted May 31, 2010 Share Posted May 31, 2010 When u start your car its in the center at the bottom. I would give it a week ir so and just check it to make sure. But im sure the smell is from the spill. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
HolyHandGrenade Posted May 31, 2010 Share Posted May 31, 2010 After about 9 years of use and maybe 1 or 2 std transmission services during that time, my transmission fluid filter became so gummed up that I leaked out a bunch of fluid and my transmission started slipping / wouldn't go into gear. Thought I was screwed / in for a $4000 transmission repair because I didn't realize what was happening. $100 worth of filter change and fluid refill got me back on the road. No problems since. *knock on wood* Link to comment Share on other sites More sharing options...
