blue dragon Posted May 31, 2010 Share Posted May 31, 2010 I have steering wheel vibration at 120km/hr and above. Before anyone thinks the tires are out of balance, I had 4 new tires put on today and the vibration is still there. Any ideas what it could be? I checked the wheel bearings, there is no play and no noises(I recently replaced one). Could it be the control arm bushings? Are there any bushings on the driveshaft or axles which could go bad? The car has 120k km on it btw. Link to comment Share on other sites More sharing options...
ehsnils Posted May 31, 2010 Share Posted May 31, 2010 A bent or damaged rim would be my guess, but check the gearbox bearings too. Pay attention to bearings related to center diff. Also listen for noises at lower speeds. That may give you a clue too. Check out this thread - it may also provide some insight: http://legacygt.com/forums/showthread.php/5mt-transmission-failure-s-128098.html Link to comment Share on other sites More sharing options...
blue dragon Posted June 1, 2010 Author Share Posted June 1, 2010 ^^ Thanks for the link Link to comment Share on other sites More sharing options...
