wrxkilla05 Posted May 27, 2010 Share Posted May 27, 2010 first off i wasnt sure what section to post this in but whatever.....so while i was under my car today installing my up + down pipes i noticed that my front tires, towards the inside right around where the top meets the sidewall is almost completely bare and rubbed down like no other and the tires have less than 15k on them and have plenty of tread everywhere else on the tire. i know this is a bad description but i couldnt think of any other way to word it and idk what is causing this but maybe someone else could help me out, thanks guys Link to comment Share on other sites More sharing options...
rurouni_x Posted May 27, 2010 Share Posted May 27, 2010 do you see the area that its rubbing on? Maybe the strut? If not it's probly camber wear. Link to comment Share on other sites More sharing options...
wrxkilla05 Posted May 27, 2010 Author Share Posted May 27, 2010 well i thought it was just the lower shock housing but i couldnt see a rubbing area....and this might be a noob question but what causes camber wear? Link to comment Share on other sites More sharing options...
Blue GT Posted May 31, 2010 Share Posted May 31, 2010 Negative camber, but if you're stock height I would assume a bad alignment (or just lack of one in a while) with toe not being at 0 probably added to the wear. Link to comment Share on other sites More sharing options...
