LegacyFuture Posted May 21, 2010 Share Posted May 21, 2010 So when I upgraded my tires to Continental ExtremeContact DWS, it started feeling way too soft and the side walls too thin... so instead of changing the tires back... I installed rallitek front/rear swaybars/endlinks. Body roll is almost gone, on normal turns and normal driving. However, that bouncy feeling is still there with these tires/suspension. What is your opinion? Keep upgrading suspension or tires? And which tires are nice and stiff, good side wall? but still comfortable. Thanks! Link to comment Share on other sites More sharing options...
mustangendsley Posted May 21, 2010 Share Posted May 21, 2010 lca bushings is next. Link to comment Share on other sites More sharing options...
LegacyFuture Posted May 21, 2010 Author Share Posted May 21, 2010 lca bushings is next. what will those do? Link to comment Share on other sites More sharing options...
mustangendsley Posted May 21, 2010 Share Posted May 21, 2010 make turning in better and not so sloppy feel. Link to comment Share on other sites More sharing options...
LegacyFuture Posted May 21, 2010 Author Share Posted May 21, 2010 make turning in better and not so sloppy feel. how long it takes to install? anything needs to be taken apart? what are the best ones for legacy gt? Link to comment Share on other sites More sharing options...
mustangendsley Posted May 21, 2010 Share Posted May 21, 2010 You have to have them pressed in, avo and rallitek have them. you have to remove the lca to do this. Link to comment Share on other sites More sharing options...
LegacyFuture Posted May 21, 2010 Author Share Posted May 21, 2010 You have to have them pressed in, avo and rallitek have them. you have to remove the lca to do this. how long is a typical installation? Link to comment Share on other sites More sharing options...
Bolksey85 Posted May 21, 2010 Share Posted May 21, 2010 Fred Beans has the Whiteline offsets on sale this month. Link to comment Share on other sites More sharing options...
berkshire40 Posted May 21, 2010 Share Posted May 21, 2010 i ordered the whiteline bushings, they have more caster adjustment. i still gotta find someone to install them though Mod list & photos _ Link to comment Share on other sites More sharing options...
LegacyFuture Posted May 21, 2010 Author Share Posted May 21, 2010 wouldn't springs be better investment? Link to comment Share on other sites More sharing options...
mustangendsley Posted May 21, 2010 Share Posted May 21, 2010 springs are good but theses bushings go out at around 30k on the car. once you get them pressed in by a shop they just bolt back in. you might have to get a alinment on the car after. If you have a shop in mind and they can do it that day then it will only be 1 day to get everything done. Link to comment Share on other sites More sharing options...
RIPjeep2002 Posted May 21, 2010 Share Posted May 21, 2010 Run your DWS at 40psi. They have soft sidewalls, but at 40psi are just perfect. Link to comment Share on other sites More sharing options...
BoozeRS05 Posted May 21, 2010 Share Posted May 21, 2010 Run your DWS at 40psi. They have soft sidewalls, but at 40psi are just perfect. This will def help with the tires. I'm not sure about 40psi, but I ran mine around 38f/36r. Secondly, I'd recommend struts and/or springs over LCA bushings. The float/bounce you feel is the lousy struts that come stock on the LGT. First mods I did to my LGT were rear sway bar and struts/springs. My $0.02 EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
LegacyFuture Posted May 21, 2010 Author Share Posted May 21, 2010 This will def help with the tires. I'm not sure about 40psi, but I ran mine around 38f/36r. Secondly, I'd recommend struts and/or springs over LCA bushings. The float/bounce you feel is the lousy struts that come stock on the LGT. First mods I did to my LGT were rear sway bar and struts/springs. My $0.02 does it get rid of that wobble feeling at 40psi? Link to comment Share on other sites More sharing options...
BoozeRS05 Posted May 21, 2010 Share Posted May 21, 2010 Side-to-side wobble could be the tire pressure (soft sidewalls or under inflated) or it could be the LCA's. Tire pressure is free and easy to play with, LCA's are not. Floating, bouncing, dive and squat are from poor dampening of the stock struts. Disclaimer: I'm no suspension expert, just commenting on what I've tried. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
berkshire40 Posted May 21, 2010 Share Posted May 21, 2010 i would say floating is mostly springs. after swapping them out it didnt feel like a caddy anymore Mod list & photos _ Link to comment Share on other sites More sharing options...
LegacyFuture Posted May 21, 2010 Author Share Posted May 21, 2010 Side-to-side wobble could be the tire pressure (soft sidewalls or under inflated) or it could be the LCA's. Tire pressure is free and easy to play with, LCA's are not. Floating, bouncing, dive and squat are from poor dampening of the stock struts. Disclaimer: I'm no suspension expert, just commenting on what I've tried. struts cost a fortune Link to comment Share on other sites More sharing options...
BoozeRS05 Posted May 21, 2010 Share Posted May 21, 2010 You're right, struts aren't cheap. Try springs with stock struts, some have been doing this for 100k miles and like their setups. Meantime, keep an eye on the classifieds or start a wtb thread for struts. I got used JDM Bilsteins with Swift springs, fully assembled, for $550 shipped 2 years ago. Track season is here, some will be upgrading to coilovers (another option). EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
Ryandigi Posted May 21, 2010 Share Posted May 21, 2010 when auto crossing I pumped em to 44psi...I hate my continentals Springs/struts or coilovers...choose your poison. Link to comment Share on other sites More sharing options...
