cucamelsmd15 Posted May 17, 2010 Share Posted May 17, 2010 As my wife has recently moved on to a '10 F150 for various reasons, I have inherited her 2006 Legacy 2.5i SE. Thankfully, I have the manual CC, so that should open my options a bit. Id like to snag a nice HU, components for the front, whatever for the rear doors, and a 10 or 12 inch sub for the trunk. I had a PG RSD10D in my WRX, and loved it. Tight, clean bass that could go low in a nice, stealth sealed enclosure. Id like to stick to the same in the Legacy, and not give up my precious trunk space, as I travel a good bit for work. The thing is, I havent shopped components and head units in over 4 years, so I have no idea whats good and whats not. Ergo, Id like some suggestions. I havent even thought about budget at this point either, but lets say "middle of the road". Id like: aforementioned stealth sub setup 4ch amp to drive mains 2/1 amp for sub (have already, 300w RMS, remote boost) Components for front Whatever for rear Nice head unit with good iPod integration (possibly) HD radio Suggestions or comments? Link to comment Share on other sites More sharing options...
Pawlwawl06 Posted May 17, 2010 Share Posted May 17, 2010 I have the Polk db6501 component set for the fronts, direct fitment and they sound really good with an amp and a sub. Link to comment Share on other sites More sharing options...
cucamelsmd15 Posted May 20, 2010 Author Share Posted May 20, 2010 Ok, so right now Im thinking: Pioneer AVH-4200 in the double din cubby Infinity 475a to drive components up front, door speakers in rear Infinity 1300a for sub Phoenix Gold rsd10d maybe? I still havent decided on front and rear speakers. I also need a nice, compact box for the sub, preferably one that mounts out of the way somewhere. Link to comment Share on other sites More sharing options...
cucamelsmd15 Posted June 1, 2010 Author Share Posted June 1, 2010 Bump Link to comment Share on other sites More sharing options...
jumpoff97 Posted June 2, 2010 Share Posted June 2, 2010 Find out the depth of the AVH-4200....if its the same as my Avic-D3 then it will stick out about an inch past the cubby, and you will have to create a "frame" for it. Behind the cubby is a metal beam so you dont a lot of space to stick the double din flat with the cubby. But I have seen other members have been able to with other brands such as Eclipse or Kenwood. If the depth is the same as my D3 then you should probably go with the option below for a cleaner look..... You should look into this and cut it to fit the double din, only $20.... http://www.crutchfield.com/p_120998901/Subaru-Legacy-Outback-In-dash-Receiver-Kit.html?tp=3121&s=0 http://a248.e.akamai.net/pix.crutchfield.com/products/2006/120/h120998901-f2p.jpg Or this which is ready to go, but $50.... http://scosche.com/products/productID/1600 http://scosche.com/ecom/images/product/1600.13213.600x400.SU2025B.jpg Link to comment Share on other sites More sharing options...
underyourbed Posted February 27, 2011 Share Posted February 27, 2011 about to do some audio work on my 06 as well. i am also in the market for a touch screen. i have the sub not really where or how i want it set up just yet but its in progress. post some picks of your installation. uyb Link to comment Share on other sites More sharing options...
bomberlegacy Posted February 27, 2011 Share Posted February 27, 2011 The Scosche faceplate is 30 bucks on amazon. Works well. '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
SubaruTim Posted February 27, 2011 Share Posted February 27, 2011 I did a quite a bit to my audio.. Scoche double din ([ame=http://www.amazon.com/Scosche-SU2025B-2005-Up-Subaru-Outback/dp/B001EBJTK6/ref=sr_1_1?ie=UTF8&s=automotive&qid=1298833649&sr=8-1]Amazon.com: Scosche SU2025B 2005-Up Subaru Legacy/Outback DIN With Pocket or Double DIN: Automotive[/ame]) Clarion double din with nav and bluetooth Alpine Type R components Alpine Type R coaxials Alpine Type R 12" subwoofer with dual voice coil Alpine MRP-M500w 4 channel to power all four speakers Alpine MRP-M650w monochannel to power the sub Just purchased some sound deadening to install when it gets nicer out. All in all it sounds fantastic, my only complaint is the rattle i get when i turn it up but hopefully the sound deadening with improve that. Also with most speakers you will need to pick up some speaker spacers because the depth on most good speakers is pretty big. There's a guy on here that makes them and sells them. Really good product. Made the install very easy. http://legacygt.com/forums/showthread.php/3-4-pvc-door-speaker-spacers-adapters-made-order-142882.html?t=142882&highlight=speaker+spacers Link to comment Share on other sites More sharing options...
