whitetiger Posted July 14, 2016 Share Posted July 14, 2016 Here's my best run from last weekend. And here's two weeks ago. I've learned a lot from others since this event. I was doing some funky things with my hands due to the tight course and 15:1 steering ratio. Boxkita thanks for the links! having watched this i'd say you are not looking ahead very well. you miss so many opportunities to apply power earlier and then you over cook the turns in other areas which throw off your line. other than the alignment/tire pressure advice and stiffer springs, take and EVO school if they come by your neck of the woods. the nut behind the wheel needs some major tightening. on a side note, taking video is a great way to learn, but your camera position is bad. try to mount outside the car on the roof pointed towards the nose of the car in order to see car/cone spacing. its one of the easiest wasy to see how good your line is. here is an old vid of mine with the camera angle im talking about. - Link to comment Share on other sites More sharing options...
boxkita Posted July 15, 2016 Share Posted July 15, 2016 Great video whitetiger. what's the program? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
whitetiger Posted July 15, 2016 Share Posted July 15, 2016 ^Solostorm with 10hz BT GPS and OBDLink MX Dongle, GoPro Hero4 Black for main camera, and Galaxy S5 front camera for cockpit. Link to comment Share on other sites More sharing options...
Cincy05LGT Posted July 15, 2016 Share Posted July 15, 2016 $200 just for the app. Not cheap! Thanks for all the pro tips guys. I'll be heading to my local performance alignment shop with the intentions of maxing negative camber, adding positive caster, and adding a hair of toe out. This is not my daily vehicle, so I'm not worried about some scrub. My goals are eventually RCE tarmacs with race springs, chassis bracing, ALK, and 245-40R18 RE71R. Also it goes without saying, I'm working on improving driving style with each event. Link to comment Share on other sites More sharing options...
whitetiger Posted July 15, 2016 Share Posted July 15, 2016 ^you dont need the app. just mount your camera up there. you plan sounds good. dont forget, take an evo school - http://evoschool.com/schools Link to comment Share on other sites More sharing options...
