richardg1952 Posted April 14, 2005 Share Posted April 14, 2005 I found the yellow and black label on the visor annoying so I peeled it off. Unfortunately it left behind a square of adhesive residue. Any ideas on how to clean it off without damaging the visor material (ivory). TIA Link to comment Share on other sites More sharing options...
D-2.5-GT Posted April 14, 2005 Share Posted April 14, 2005 little bit of goo gone works wonders. Put some on and let it soak in for a second, then rub away, the sticky stuff will kind of flake off a bit. Don't be worried, the liquid might make the visor look stained afterwords, it dries away. Did one of mine just the other day Link to comment Share on other sites More sharing options...
almondcookie Posted April 14, 2005 Share Posted April 14, 2005 goo gone straight from the bottle? my sprayer doesn't work. goo gone is almost as thick as molasses so i have to do the rag over the top and tip it over style. do you at least make the towel or rag wet or just dry? goo gone is suppose to be some really strong stuff. Link to comment Share on other sites More sharing options...
D-2.5-GT Posted April 14, 2005 Share Posted April 14, 2005 I did the onto a rag then onto the visor, still could see right away where the goo gone kind of soaked in. Then i took that same rag and rubbed back and forth. After it dried up a little, the sticky substance started to flake off with the rag rubbing it. Then let the visor dry, it will dry normal. You won't need much, just enough to cover the area a little...i wouldn't dump it straight on as you will probably use too much. Link to comment Share on other sites More sharing options...
OCDetails Posted April 19, 2005 Share Posted April 19, 2005 Any luck with this? How did it go? _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
richardg1952 Posted April 19, 2005 Author Share Posted April 19, 2005 I haven't worked up the nerve to try this yet. Link to comment Share on other sites More sharing options...
D-2.5-GT Posted April 19, 2005 Share Posted April 19, 2005 there is really nothing to be scared of on this one.... Link to comment Share on other sites More sharing options...
