quick4dr Posted May 3, 2010 Share Posted May 3, 2010 just received my uppipe from nasioc, 04 STI. When i look in it though i see a mesh like screen, isnt that a cat? Shouldn't 04 be straight thru no cat? what size drain plug can I use to plug the sensor port? Link to comment Share on other sites More sharing options...
coldradio1 Posted May 3, 2010 Share Posted May 3, 2010 I thought the STI up didn't have a EGT sensor? Also, it should have an accordion style flex, but not a cat. Link to comment Share on other sites More sharing options...
scoobydoobie Posted May 3, 2010 Share Posted May 3, 2010 Sounds like you got an 02-05 WRX catted UP Link to comment Share on other sites More sharing options...
quick4dr Posted May 5, 2010 Author Share Posted May 5, 2010 ok so if thats the case, what should I use to gut it? large screw driver and just shatter out the insides? Link to comment Share on other sites More sharing options...
coldradio1 Posted May 5, 2010 Share Posted May 5, 2010 Drill bit is what several of my friends have used. Make sure you get everything out of there. Last thing you need is little loose pieces of metal getting sucked into the turbo. Link to comment Share on other sites More sharing options...
hakgwai Posted May 6, 2010 Share Posted May 6, 2010 also wear a mask. you dont want to be breathing the stuff that comes out. Link to comment Share on other sites More sharing options...
Rexwagon Posted May 8, 2010 Share Posted May 8, 2010 i would ask for a refund if it was labeled as an sti up pipe. thats false advertising. Link to comment Share on other sites More sharing options...
boost4life Posted May 8, 2010 Share Posted May 8, 2010 I'm with this, Sounds like a 02-05 wrx uppie and having gutted one before, it's no easy task, it's time consuming I used a drill bit extension and put in several holes then punched them out i used a die grinder to remove the rest and a flapper wheel to finish it inside to a smooth surface. i would ask for a refund if it was labeled as an sti up pipe. thats false advertising. Link to comment Share on other sites More sharing options...
