boletole Posted May 1, 2010 Share Posted May 1, 2010 hi, i just noticed this in past couple of days that when the car is running and it is engaged in a gear upon taking the foot off the clutch it makes some sort of whirling noise. checked the oil in the transmission box it seems like it is at the desirable level at the moment around half way between full and add. WHAT COULD BE A PROBLEM?. THE CAR HAS DONE A BIT OVER 240 K. is the clutch a problem?? Thanks in advance for any help provided!! Link to comment Share on other sites More sharing options...
